SpencerL Posted May 27, 2008 Share Posted May 27, 2008 (edited) Hey, I created a shadow shader which I apply to my light and it colors the shadows. I have created a color parameter on my light called "shadcol". I want to bring that parameter into my VOP network. I tried a parameter VOP and named it "shadcol" but it does not seem to bring in that parameter. Is there something that I am missing to bring the "shadcol" parameter into my Vopnet? Thanks Edited May 27, 2008 by SpencerL Quote Link to comment Share on other sites More sharing options...
eetu Posted May 27, 2008 Share Posted May 27, 2008 (edited) I haven't touched light shaders, but "Import Light Variable" VEX node sounds like it could be what you need? eetu. EDIT: oops, I completely misread/understood - please disregard Edited May 27, 2008 by eetu Quote Link to comment Share on other sites More sharing options...
symek Posted May 27, 2008 Share Posted May 27, 2008 SpencerL said: Hey,I created a shadow shader which I apply to my light and it colors the shadows. I have created a color parameter on my light called "shadcol". I want to bring that parameter into my VOP network. I tried a parameter VOP and named it "shadcol" but it does not seem to bring in that parameter. Is there something that I am missing to bring the "shadcol" parameter into my Vopnet? Thanks I suppose that you have to link (with ch() expression) your light parameter with a shader parameter and use that in shader's body. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted May 28, 2008 Author Share Posted May 28, 2008 Quote I suppose that you have to link (with ch() expression) your light parameter with a shader parameter and use that in shader's body. Thanks Symek, Good suggestion. That sounds like it could work, even though it is somewhat of a hack. I am very new to creating shadow/light shaders and I am wondering if I am going about this in the wrong direction because it seems that there should be a way to import light parameters into light/shadow shaders, just as you can import attributes for surface shaders. Thanks! Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted May 28, 2008 Share Posted May 28, 2008 SpencerL said: it seems that there should be a way to import light parameters into light/shadow shaders, just as you can import attributes for surface shaders. You can't because these are parameters, not attributes. In a light, there's no geometry to bind attributes to, so they can't in turn override shader parameters of matching name/type (the concept of bound attributes just doesn't exist for a light -- there's nothing to bind them to). Quote Link to comment Share on other sites More sharing options...
