kensonuken Posted August 23, 2008 Share Posted August 23, 2008 I would like to write certain shaders and to generate multiple passes at a time... I would like to know whats the command in IFD as well as how would be a vex code for it.. pls help.. Quote Link to comment Share on other sites More sharing options...
Jason Posted August 23, 2008 Share Posted August 23, 2008 I would like to write certain shaders and to generate multiple passes at a time... I would like to know whats the command in IFD as well as how would be a vex code for it.. pls help.. VEX: You have to declare shader parameters as "export" in order to get them to be able to be exported. surface myshader( vector diffuse=1; export vector myoutvar = 0 ) { ... } In VOPs, you use a Parameter VOP and toggle Export and wire the data into the left side of the node. IFD: There are a few IFD commands to do this. If I was you I'd just set a Disk File on your Mantra ROP (which you have set up to export Extra Image Planes) and examine the .ifd in a text editor. Please note that Apprentice will not write IFD disk files out. You need a commercial license for that. Jason Quote Link to comment Share on other sites More sharing options...
sl0throp Posted September 20, 2008 Share Posted September 20, 2008 Jason, Can you show me how you would layer a simple shading model, for instance a Lambert for diffuse, a specular model, a refection and ambient occlusion and have them export the variables I am unable to get passed the diffuse and specular with my puny brain. Also is there a way to output a generalized occlusion pass on a scene level rather than on a shader level like you can with Pz, etc. Thanks for any guidance here... s Quote Link to comment Share on other sites More sharing options...
ihab Posted September 20, 2008 Share Posted September 20, 2008 Check the hipfile in this thread Link check the shader as well as the mantra rop to see how the AOVs are exported as channels in a single exr file Cheers Quote Link to comment Share on other sites More sharing options...
