Jason Posted November 13, 2008 Share Posted November 13, 2008 Lighting, materials, geometry, texturing - There's some buffer stuff to be fixed before the full range lighting / post fx / etc come online, but I thought I'd post a progress shot: I like it! Fun stuff, it seems? Quote Link to comment Share on other sites More sharing options...
mondi Posted November 13, 2008 Author Share Posted November 13, 2008 I like it! Fun stuff, it seems? Definitely! Just need to petition the universe for that 36 hour day so I can work on this for more than a couple of hours a day Quote Link to comment Share on other sites More sharing options...
mondi Posted November 15, 2008 Author Share Posted November 15, 2008 (edited) A little better lighting, better transparency support, normal mapping( with some brokenness, a hack for now ) Still need to update my light buffer setup so I can use the engine's internal render layer setup .. hopefully this weekend. Quick question: Currently I'm using the gdp pointer as an ID for the incoming data, so I can buffer as much as possible, I'd like to use the actual object ID if possible, and query topology / data changes - is this possible at all? Is it even possible to extract OP / OBJ information from a GU_Detail? edit:: Just realized that this is what's being done internally in Houdini to an extent, which I'm pretty much overriding with the display list environment option. I guess I'll try linking the materials to the lights so that changes get pushed. Have a nice weekend. Edited November 15, 2008 by mondi Quote Link to comment Share on other sites More sharing options...
edward Posted November 15, 2008 Share Posted November 15, 2008 In addition to the gdp pointer, I would also check whether the value of GU_Detail::getMetaCacheCount() is different. Quote Link to comment Share on other sites More sharing options...
mondi Posted November 15, 2008 Author Share Posted November 15, 2008 In addition to the gdp pointer, I would also check whether the value of GU_Detail::getMetaCacheCount() is different. Thanks edward, I'll give that a try as soon as I get a free moment Quote Link to comment Share on other sites More sharing options...
mondi Posted November 17, 2008 Author Share Posted November 17, 2008 First pass with new light-buffer setup. Some weirdness with context size / fbo sizing, but nothing that seems insurmountable. Quote Link to comment Share on other sites More sharing options...
mondi Posted November 25, 2008 Author Share Posted November 25, 2008 Not a fun image reply.. I'm in the middle of some pretty major production crunch right now, so time is a little scarce I did fix the sizing / aspect ratio stuff though, so as soon as I finish the Houdini side of things for this project, I'll reinstall the dso and put up a couple of new pics. But now, sleep time.. Quote Link to comment Share on other sites More sharing options...
Jason Posted November 25, 2008 Share Posted November 25, 2008 Not a fun image reply..I'm in the middle of some pretty major production crunch right now, so time is a little scarce I did fix the sizing / aspect ratio stuff though, so as soon as I finish the Houdini side of things for this project, I'll reinstall the dso and put up a couple of new pics. But now, sleep time.. I don't know what it is, but I like it! Looking forward to seeing your next series... Quote Link to comment Share on other sites More sharing options...
mondi Posted December 10, 2008 Author Share Posted December 10, 2008 Project went great Fixed up some issues with relative positioning tonight.. All my test models were at the origin before, so I didn't catch this one earlier. I thought I'd post a quick comparison: Lights / Model are identical, and the materials are as similar as I could get them within the available parameters. The next step is to read values from the default Houdini material types. 1 - VEX Super Material ( I can't test the OGL2 stuff as Houdini on OSX doesn't support that path last I checked ) 2 - Same scene - similar camera, with my renderer / custom material: And finally - unresized render: Quote Link to comment Share on other sites More sharing options...
mondi Posted December 11, 2008 Author Share Posted December 11, 2008 (edited) There are some issues with camera projection - I'm not entirely sure how to extract the info I need from the HDK, but I thought I'd add this anyway: Simple model + 1 light + video: Everything so far has used my somewhat ambiguous models edit:: Removed the video temporarily. I need to fix some problems with my website Edited January 29, 2009 by mondi Quote Link to comment Share on other sites More sharing options...
mondi Posted December 29, 2008 Author Share Posted December 29, 2008 What a lovely vacation - hope you guys got some time to decompress Been working on the post fx / layering / buffer system in preparation for deferred shading and a better shadow map implementation - and as a side project, I thought I'd do some experiments with screen space ambient occlusion. It's not quite right yet, and there's much tweaking to be done, but the results are encouraging so far. Very little hit on framerate which is nice - 100% GPU calculated. Quote Link to comment Share on other sites More sharing options...
mondi Posted December 29, 2008 Author Share Posted December 29, 2008 Second pass. No blurring or fanciness yet, but the basics are fleshing out nicely. Quote Link to comment Share on other sites More sharing options...
Jason Posted December 30, 2008 Share Posted December 30, 2008 Second pass. No blurring or fanciness yet, but the basics are fleshing out nicely. Hey Mondi! I love what you're doing, but it'd be nice to know how it differs from the unmodified OpenGL viewport.. any chance you can post a comparison pic? Also; since you've got your fingers deep into this.. have you looked a trying a SSAO (Screen-Space Ambient Occlusion) renderer? Quote Link to comment Share on other sites More sharing options...
mondi Posted December 30, 2008 Author Share Posted December 30, 2008 Hey Mondi!I love what you're doing, but it'd be nice to know how it differs from the unmodified OpenGL viewport.. any chance you can post a comparison pic? Also; since you've got your fingers deep into this.. have you looked a trying a SSAO (Screen-Space Ambient Occlusion) renderer? Sure thing - That's exactly what I'm working on right now . Houdini standard viewport, 1 pointlight Viewport, 1 pointlight, with pass3 of SSAO, still tweaking parameters. There's obviously a great amount of work to be done, but I'm pretty happy with the results thus far. There is a little trickery going on in those pictures - I had to increase the pointlight falloff for the standard viewport so you could see anything, so it's a tad more contrasty just by default. Both are straight captures though - no post processing other than scaling Quote Link to comment Share on other sites More sharing options...
Netvudu Posted December 30, 2008 Share Posted December 30, 2008 you Quote Link to comment Share on other sites More sharing options...
mondi Posted January 3, 2009 Author Share Posted January 3, 2009 you Quote Link to comment Share on other sites More sharing options...
Jason Posted January 3, 2009 Share Posted January 3, 2009 Thanks - I'd love to see people using this stuff, just need to tie it all together a bit more We'd love to:) Are you going to post the source-code, perhaps? Latest: More tweaks to the ssao shader, with rudimentary depth of field. It's almost time to do an optimization pass, but this currently runs at around 14fps @ 1675 * 1280 with 4xMSAA. This is very very nice work, thanks Mondi. Just looking at your occlusion effect, it seems to cast a "shadow" on the background, making it appear as if there is a sheet of paper underneath the scene, which kinda defeats some of the distant depth feel. Is there a way to stop that? Wouldn't it be cool if SESI could come up with a way to pass arguments to RenderHook plugins, perhaps a new "Viewport Plugins" section in the Display Options? Along with a way to bypass these plugins with a toggle. Currently the only way I'm aware of for doing such a thing is to analyze geometry detail attributes - which are not really appropriate for global viewport settings. Quote Link to comment Share on other sites More sharing options...
mondi Posted January 3, 2009 Author Share Posted January 3, 2009 We'd love to:) Are you going to post the source-code, perhaps? This is very very nice work, thanks Mondi. Just looking at your occlusion effect, it seems to cast a "shadow" on the background, making it appear as if there is a sheet of paper underneath the scene, which kinda defeats some of the distant depth feel. Is there a way to stop that? Yeah, I'm not discarding any samples based on the depth comparison yet, It's on the list. Plus, once I get the depth peeling setup implemented, I'll be working with multiple depth buffers, which should get rid of most of those sort of artifacts, as well as allow for better occlusion inside clusters of objects... So many items on the list Between platform specific code, and parts of the code that are a little secret ( - Got some ideas going) It'll be a bit before any source is posted, but I'm definitely looking to put together a binary distribution in the nearish future, which I'll happily release along with any relevant script interfaces / header files Wouldn't it be cool if SESI could come up with a way to pass arguments to RenderHook plugins, perhaps a new "Viewport Plugins" section in the Display Options? Along with a way to bypass these plugins with a toggle. Currently the only way I'm aware of for doing such a thing is to analyze geometry detail attributes - which are not really appropriate for global viewport settings. That's something I've been thinking a lot about recently. My plan is to clean up the actual hook soon, and get together a list of requests for the hdk interface. I'm sure if we got a few heads together, we could come up with quite a few ideas. Quote Link to comment Share on other sites More sharing options...
edward Posted January 5, 2009 Share Posted January 5, 2009 Well, instead of using attributes, one could also use one of the display options when overriding GR_RenderHook::getWireMask() and GR_RenderHook::getShadedMask(). Now that there's custom display options, one could easily create one and use some predefined name for enabling/disabling render hooks. Take a look at GR_DisplayOption's getUserOption() and getUserOptionState() methods. Quote Link to comment Share on other sites More sharing options...
mondi Posted January 13, 2009 Author Share Posted January 13, 2009 (edited) Well, instead of using attributes, one could also use one of the display options when overriding GR_RenderHook::getWireMask() and GR_RenderHook::getShadedMask(). Now that there's custom display options, one could easily create one and use some predefined name for enabling/disabling render hooks. Take a look at GR_DisplayOption's getUserOption() and getUserOptionState() methods. I'll definitely look into that. Sorry for the long delay - between getting an awful cold, and looking for work, I've been a bit preoccupied Anyway, found and fixed a fairly embarrassing lighting problem, and am starting to put the engine back together after tearing it apart to integrate the new buffer system. What's nice now, is that with just a little more work, I can implement a fairly extensive post effects system, with very little overhead other than the actual shading time Edited January 13, 2009 by mondi Quote Link to comment Share on other sites More sharing options...
