A robot rig WIP
ofer
Hi, I'm working on a rig for my robot model. I have made some good progress so far, but still have a lot to do.
Here is a quick test animation.
I also have a little problem:
I have a HDA for the leg rig, and I have a CHOP network in it. Some of the geometry is driven a rotation channel of one of the bones in a non-linear way, so I use the 'chop' expression to sample the rotation value. But the channel name contains the full path to the CHOP. Something like "/locust/leftLegRig/KinCHOPS/invKin_Chop/legBone2:rx". This is a problem because I want to reference the "legBone2:rx" from both the left/right asset instance. Is using the rename CHOP the correct solution?
rigTest.mov
Here is another test animation.
I still have problems with my feet positions. I want them to stay planted on the ground, but they are floating around as I move the body control. The roots of the leg's bones are parented to the body control, and I use the IK with Constraints solver, so maybe thats the cause of this.
Any suggestions on how to solve it?
Thanks.
rigTest2.mov
I need the bones to rotate in particular directions. They should only rotate around the X axis, and not Y/Z, because this will cause the mesh to penetrate itself. The robot will "break". And i also need to limit the rotation around the X axis, for the same reason.
I refined the rest position of the bones, and also found that it is better to parent the mesh to the bones before setting the rest angles, and not after.
I also added ammo chains, driven by DOPs.
I animated a quick walk cycle.
walk2.mov
Really?
The hip (first) bone is not limited to one axis, but the angles are limited. If I wont use constraints, it will be very easy to cause self-penetrations.
And the bone will rotate around in directions I don't want them to. Maybe I'm missing something here. Ill try.
