musickent Posted April 15, 2003 Share Posted April 15, 2003 i am building a skirt for my spirit. but don't know how to model the pieces of decorations. i tried the copy sops, but not successful. could some one give me some idea? thanks a lot. Quote Link to comment Share on other sites More sharing options...
musickent Posted April 15, 2003 Author Share Posted April 15, 2003 emm.here is my new model. just missing the nice skirt ... Quote Link to comment Share on other sites More sharing options...
michael Posted April 16, 2003 Share Posted April 16, 2003 hmmm.... I would model one then use the copy sop on a few curves... what problems did you have with copy sop? Quote Link to comment Share on other sites More sharing options...
musickent Posted April 16, 2003 Author Share Posted April 16, 2003 the problem is the pieces are not in right position after copy.. emmm. can i copy the prototype to the points' normals? because i can manage the normal of each point to right direction.. Quote Link to comment Share on other sites More sharing options...
michael Posted April 16, 2003 Share Posted April 16, 2003 check out the Align OP it can give you lots of control HTH Quote Link to comment Share on other sites More sharing options...
musickent Posted April 16, 2003 Author Share Posted April 16, 2003 not sure how to do.. are you saying align each piece to each point? Quote Link to comment Share on other sites More sharing options...
edward Posted April 16, 2003 Share Posted April 16, 2003 Maybe this might be helpful? http://odforce.net/forum/index.php?s=8c262...pe=post&id=4999 Quote Link to comment Share on other sites More sharing options...
Mcronin Posted April 16, 2003 Share Posted April 16, 2003 Make a curve, resample the curve so it's segments are even, sweep the plate onto the curve, append a transform between the plate object and the sweep SOP, and rotate the plate into position. If you are careful about how the plate is aligned to begin with it's a snap. I didn't put much thought into this file, but I just realized, if you align the original plate in a way that makes sense to start with, and make the handle on the transform SOP persistant, you'll have a handy little animation control so you can jostle the plates with slight rotations while the character walks. skirt.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Mcronin Posted April 16, 2003 Share Posted April 16, 2003 Really good work BTW. Quote Link to comment Share on other sites More sharing options...
Jason Posted April 16, 2003 Share Posted April 16, 2003 Here is an alternate way, if you like.. Very nice model! skirt_jason.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Mcronin Posted April 16, 2003 Share Posted April 16, 2003 Alternate? That's like the perfect solution. Quote Link to comment Share on other sites More sharing options...
Jason Posted April 16, 2003 Share Posted April 16, 2003 Mcronin said: Alternate? That's like the perfect solution. Nothings perfect. Ever. Ever ever ever. Quote Link to comment Share on other sites More sharing options...
musickent Posted April 16, 2003 Author Share Posted April 16, 2003 wow..really big help for me.!!!!! it works nicely for the shirt. thank you all, guys..cheer here is the new model with the skirt on. Quote Link to comment Share on other sites More sharing options...
cs00bren Posted April 20, 2003 Share Posted April 20, 2003 nice model the heads really good what are you going to do with the model, it will be fat what ever it is. bren Quote Link to comment Share on other sites More sharing options...
