hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 (edited) do you mean the raybias in the glassproperties ? my ior is 1/1.488 and like i ve said i use one shader for all objects.... and it looks the the raybias in the shaderproperties is lower than al thicknessvalues in the scene...... hm i dont know ... it looks a little strange you re right but .... ? does the flask really look like solid glass for you .... i placed a mesh with a liquid shader inide ... rel fluids .... hm maybe i should try that here is the scene again impala_pokal_v6.hipnc Edited March 24, 2009 by hatrick Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 and.... what do you think .... the strong refelction of the water in the flask ... how would you control it ? i think it comes from the huge white reflector at the back of the pocal which is placed for the transparent(refractive) glassparts in the scene..... hm ?! Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 does the flask really look like solid glass for you .... i placed a mesh with a liquid shader inide ... rel fluids .... hm maybe i should try that here is the scene again Yeah, I mean the neck of the flask - not the body of liquid. I'll take a look at your scene in a second:) Quote Link to comment Share on other sites More sharing options...
horizon1231 Posted March 24, 2009 Share Posted March 24, 2009 and.... what do you think .... the strong refelction of the water in the flask ... how would you control it ?i think it comes from the huge white reflector at the back of the pocal which is placed for the transparent(refractive) glassparts in the scene..... hm ?! could u upload texture? Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 just give me a second i need to convert Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 ok ... floorreflection and environment... Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 ?? ... no rat files ... sry no maps at the moment i stuck with rendering Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 the glassarm looks somehow better with the ior set to 1/1.08 .... strange but.... the bulb does not ior_1_1.09.tiff Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 Yeah, I mean the neck of the flask - not the body of liquid. I'll take a look at your scene in a second:) Yeah, I found that your mantra1 ROP>PBR>Raytracing Bias was 0.1 - which is longer than the thickness of your glass, making the ray step over the reverse side of the glass; so the ray then didn't get refracted back, and went on to strike the far side of the glass, being diverted further and then missing the next opportunity to get refracted back yet again. The rule of thumb with Ray Bias is that you should have the Bias set to the smallest value possible before you start seeing glitchey self-intersection artifacts. Otherwise you must endeavor to reproduce every reflection and refraction possible by keeping this number as small as possible. Take care to make your Reflect + Refract Limits as high as reproduce every noticable light interaction too. 4 refraction bounces for the fluid in the flask is too few - since there are at least 6 interfaces that a ray must pass through, right? 2 glass refractions, then 2 liquid, then 2 glass again. The Glass Material has a fairly low default here. Getting the right refraction from the water in the flask is also a little tricky. Be sure to try to get all the refractions going. Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 so... Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 do you have the time for some tiny tweaks on the glass in my scene...? i think a hip file would help me a lot... thx for the info it sounds logic... i tried to lower the bias value in the mantratab but somehow the tube looks the same as before.... Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 do you have the time for some tiny tweaks on the glass in my scene...? i think a hip file would help me a lot...thx for the info it sounds logic... i tried to lower the bias value in the mantratab but somehow the tube looks the same as before.... Up the Glass material Refract Limit and Reflect Limit to 8, 8 Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 ok i ll try .... maybe i post something tomorrow .... 4 o clock in the morning here ... thanks a lot!! for your tips jason Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 one more thing ..... .... sorry Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 ok i ll try .... maybe i post something tomorrow .... 4 o clock in the morning here ...thanks a lot!! for your tips jason Did it work for you? Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 ok here is a new render.... i incresed the refl an refr limit to 10+ for the glass and basic liquit...for the glassarm the only way for me to get a propper result was to decrease the ior balance from 1/1,488 to 1/1,20... Strange thing is that scattered piece of geo in my whater.... thanks a lot for your help guys... Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 ok here is a new render.... i incresed the refl an refr limit to 10+ for the glass and basic liquit...for the glassarm the only way for me to get a propper result was to decrease the ior balance from 1/1,488 to 1/1,20... Strange thing is that scattered piece of geo in my whater.... thanks a lot for your help guys... Looks great now! Well done. That piece of geometry is probably where the water is close to the flask - and the raybias is sometimes skipping it, sometimes not. To all intents of and purposes, considered co-planar due to the ray bias inaccuracy. Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 i lowered the raybias as far as the scene let me but it`s still higher than at least the thickness of my bottle... Quote Link to comment Share on other sites More sharing options...
Jason Posted March 24, 2009 Share Posted March 24, 2009 i lowered the raybias as far as the scene let me but it`s still higher than at least the thickness of my bottle... Out of curiosity, have you tried a photon caustic version? You have good surfaces for it.. (although not very focussed light sources). Quote Link to comment Share on other sites More sharing options...
hatrick Posted March 24, 2009 Author Share Posted March 24, 2009 i ve never done that before .... i ll try to figure out what exactly a photon caustics version is ... Quote Link to comment Share on other sites More sharing options...
