graham Posted May 16, 2009 Share Posted May 16, 2009 Has anyone managed to get all three of these to play happily together? I just decided to plug an Intuos 3 into my new machine running 9.04 and whenever it is plugged in and I attempt to use Houdini the interface doesn't respond to mouse events. I can use the keyboard to enter commands and click on the tab menu entries but other than that I can't get any sort of input from either my mouse or tablet. Unplugging the tablet causes it to happily work again and I've had no problems with the tablet in a couple other test programs. I'm thinking it's a result of the fact that they have new hotplugging for Wacoms using hal but I can't really figure out any solution. Quote Link to comment Share on other sites More sharing options...
vmuriel Posted May 16, 2009 Share Posted May 16, 2009 (edited) I am searching a solution for this too, but no luck. http://www.sidefx.com/index.php?option=com...pic&t=15725 Edited May 17, 2009 by vmuriel Quote Link to comment Share on other sites More sharing options...
DaJuice Posted May 16, 2009 Share Posted May 16, 2009 I'm having a bit better luck on PCLOS. First of all, when I plug in the Intuos3, I have to restart X for it to go into absolute mode. After that, everything is peachy (except for missing pressure support in Houdini that you have in Windows ). Maybe it's worthwile comparing configs. This is default PCLOS, I haven't messed with it: linuxwacom 0.8.2 linuxwacom-controlpanel 0.8.2 xorg version 1.4.0.90 xorg.conf: # File generated by XFdrake (rev 247269) # ********************************************************************** # Refer to the xorg.conf man page for details about the format of # this file. # ********************************************************************** Section "Files" # font server independent of the X server to render fonts. FontPath "unix/:-1" # minimal fonts to allow X to run without xfs FontPath "/usr/share/fonts/misc:unscaled" EndSection Section "Extensions" Option "Composite" EndSection Section "ServerFlags" #DontZap # disable <Crtl><Alt><BS> (server abort) #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching) AllowMouseOpenFail # allows the server to start up even if the mouse does not work EndSection Section "Module" Load "dbe" # Double-Buffering Extension Load "v4l" # Video for Linux Load "extmod" Load "type1" Load "freetype" Load "/usr/lib/xorg/modules/extensions/nvidia/libglx.so" # 3D layer EndSection Section "InputDevice" Identifier "Keyboard1" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "us" Option "XkbOptions" "compose:rwin" EndSection Section "InputDevice" Identifier "Stylus1" Driver "wacom" Option "Device" "/dev/input/by-id/usb-Tablet_PTZ-430-event-mouse" Option "Type" "stylus" EndSection Section "InputDevice" Identifier "Eraser1" Driver "wacom" Option "Device" "/dev/input/by-id/usb-Tablet_PTZ-430-event-mouse" Option "Type" "eraser" EndSection Section "InputDevice" Identifier "Cursor1" Driver "wacom" Option "Device" "/dev/input/by-id/usb-Tablet_PTZ-430-event-mouse" Option "Type" "cursor" EndSection Section "InputDevice" Identifier "Pad1" Driver "wacom" Option "Device" "/dev/input/by-id/usb-Tablet_PTZ-430-event-mouse" Option "Type" "pad" EndSection Section "InputDevice" Identifier "Mouse1" Driver "mouse" Option "Protocol" "ExplorerPS/2" Option "Device" "/dev/mouse" EndSection Section "InputDevice" Identifier "SynapticsMouse1" Driver "synaptics" Option "EdgeMotionMinSpeed" "200" Option "MinSpeed" "0.8" Option "MaxSpeed" "1.00" Option "BottomEdge" "650" Option "EdgeMotionMaxSpeed" "200" Option "UpDownScrolling" "0" Option "CircScrollTrigger" "2" Option "SHMConfig" "on" Option "LeftEdge" "120" Option "FingerLow" "14" Option "HorizScrollDelta" "20" Option "MaxTapMove" "110" Option "FingerHigh" "15" Option "VertScrollDelta" "20" Option "CircularScrolling" "1" Option "AccelFactor" "0.015" Option "TopEdge" "120" Option "RightEdge" "830" EndSection Section "Monitor" Identifier "monitor1" VendorName "Generic" ModelName "Flat Panel 1280x800" HorizSync 31.5-90 VertRefresh 60 # TV fullscreen mode or DVD fullscreen output. # 768x576 @ 79 Hz, 50 kHz hsync ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630 # 768x576 @ 100 Hz, 61.6 kHz hsync ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616 # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_120" 181.21 1280 1376 1520 1760 800 801 804 858 -HSync +Vsync # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_100" 147.89 1280 1376 1512 1744 800 801 804 848 -HSync +Vsync # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_85" 123.38 1280 1368 1504 1728 800 801 804 840 -HSync +Vsync # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_75" 107.21 1280 1360 1496 1712 800 801 804 835 -HSync +Vsync # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_60" 83.46 1280 1344 1480 1680 800 801 804 828 -HSync +Vsync # modeline generated by gtf(1) [handled by XFdrake] ModeLine "1280x800_50" 68.56 1280 1336 1472 1664 800 801 804 824 -HSync +Vsync EndSection Section "Device" Identifier "device1" VendorName "nVidia Corp." BoardName "NVIDIA GeForce 7 Series" Driver "nvidia" Option "DPMS" Option "UseEdidDpi" "False" Option "AddARGBGLXVisuals" "True" Option "DPI" "96 x 96" EndSection Section "Screen" Identifier "screen1" Device "device1" Monitor "monitor1" DefaultColorDepth 24 Subsection "Display" Depth 8 Modes "1280x800" EndSubsection Subsection "Display" Depth 15 Modes "1280x800" EndSubsection Subsection "Display" Depth 16 Modes "1280x800" EndSubsection Subsection "Display" Depth 24 Modes "1280x800" EndSubsection EndSection Section "ServerLayout" Identifier "layout1" InputDevice "Keyboard1" "CoreKeyboard" InputDevice "Stylus1" "SendCoreEvents" InputDevice "Eraser1" "SendCoreEvents" InputDevice "Cursor1" "SendCoreEvents" InputDevice "Pad1" "SendCoreEvents" InputDevice "Mouse1" "CorePointer" InputDevice "SynapticsMouse1" "SendCoreEvents" Screen "screen1" EndSection I doubt these are relevant but what the heck. cat /etc/hotplug/blacklist audio snd-usb-audio cat /etc/modprobe.d/blacklist-mdv # blacklisted modules for PCI coldplug # see also /etc/modprobe.d/blacklist-compat blacklist rivatv # For some bridges both intel-agp and i82875p_edac are loaded. If i82875p_edac # is loaded first it will grab the device. Then intel-agp doesn't work. # Therefore we disable automatic loading of 82875p_edac. (Bug 213840) # https://bugzilla.novell.com/show_bug.cgi?id=213840 blacklist i82875p_edac # do not use "Boot Protocol" drivers, we prefer usbhid # and they cause problems when loaded together with usbhid (#37726, #40861) blacklist usbkbd blacklist usbmouse Quote Link to comment Share on other sites More sharing options...
vmuriel Posted May 17, 2009 Share Posted May 17, 2009 Thanks DaJuice for the info. But I think that the new Ubuntu hotplugging system isn't the problem. My xorg.conf is Section "Monitor" Identifier "Configured Monitor" EndSection Section "Screen" Identifier "Default Screen" Monitor "Configured Monitor" Device "Configured Video Device" DefaultDepth 24 EndSection Section "Module" Load "glx" EndSection Section "Device" Identifier "Configured Video Device" Driver "nvidia" Option "NoLogo" "True" EndSection All the inputs drivers are controlled automatically in the fly. It works great, but no luck with Houdni. I have disabled the hotplugging system using Section "ServerFlags" Option "AutoAddDevices" "False" EndSection And I have modified the xorg.conf manually like in your files. Again all works, wacom, etc ... but no luck with Houdini. Conclusion, it seems the new hotplugging staff isn't the problem. Quote Link to comment Share on other sites More sharing options...
edward Posted May 18, 2009 Share Posted May 18, 2009 I am searching a solution for this too, but no luck.http://www.sidefx.com/index.php?option=com...pic&t=15725 I find this a strong probably cause Wacom support is terribly broken in the latest Xorg thanks to xinput 1.5 and hal..... except for missing pressure support in Houdini that you have in Windows As for Windows, certain Wacom tablet drivers had missing 64-bit Wintab32.dll's. If you're on Windows 64-bit and your tablet has no pressure at all, then make sure you have the file C:\Windows\System32\WinTab32.dll (using a 64-bit app like Windows Explorer). Using the latest 10.0 daily build has fixes for occasional pressure lost under Windows. Quote Link to comment Share on other sites More sharing options...
DaJuice Posted May 18, 2009 Share Posted May 18, 2009 I find this a strong probably causeAs for Windows, certain Wacom tablets had missing 64-bit Wintab32.dll's. If you're on Windows 64-bit and your tablet has no pressure at all, then make sure you have the file C:\Windows\System32\WinTab32.dll (using a 64-bit app like Windows Explorer). Using the latest 10.0 daily build has fixes for occasional pressure lost under Windows. Sorry Edward, that sentence came out wrong I guess. I meant that linux versions of Houdini lack pressure support (at least in my experience). Quote Link to comment Share on other sites More sharing options...
vmuriel Posted May 23, 2009 Share Posted May 23, 2009 This should be fixed in tomorrow's daily build (Houdini 10.0.289). http://www.sidefx.com/index.php?option=com...pic&t=15725 Quote Link to comment Share on other sites More sharing options...
DaJuice Posted May 23, 2009 Share Posted May 23, 2009 Pressure support workssss. Quote Link to comment Share on other sites More sharing options...
Marc Posted May 23, 2009 Share Posted May 23, 2009 http://www.sidefx.com/index.php?option=com...pic&t=15725 huzzah! Happy days . Quote Link to comment Share on other sites More sharing options...
