Particle Fluid Surfacer not promoting any of the particle attributes
bhaveshpandey
hey i was working on a little personal project involving POPs....
when i use a particle fluid surfacer, i was not able to use Velocity Motion Blur (i checked the options for the same..again)
after a look at the details view, I realised that this node was not transferring the Velocity attribute to the surface....(details view showed a velocity of 0)
I also tried to transfer colour and again, it dint really do anything..
has anyone had similar issues ??
I'm running Houdini 10.
thanks :D
thanks :D
There is an Attributes tab on the particle fluid surface SOP where you would specify any of the attributes which you want to pass in, ie v Cd
hey Spencer thanks for the quick reply!!
I did select the attributes in the Attributes tab..but still its not passing them through..
I thought this was probably happening coz of speed stretching option which I had enabled..but thats not the problem i
guess after reading the help notes..I even relaunched Houdini and did a quick test in a new scene..
here's the hip file for it..
(pls let me know if you see everything alright..it might be some issue with the version or something)
fluidSurfacer_Test.hip
Edited by bhaveshpandey
hmm...seems to work fine on my end. Both v and Cd exist on the pfluid surfce sop. Im using H10.0.249
