Fomal Posted July 5, 2009 Share Posted July 5, 2009 hi guys!Someone can tell me how to obtain that fine detail as can be seen in the 10th blast off video on the sidefx site. I tried bunch of things like increasing curl on the upres pyro solver, or adding vorticles to the lores fluid, adjusted the shader but cant get the detail, all i get is big puffs. I suspect that it is noise mapped to density but can someone help me please? Thanks in advance! Hi, That is simmed detail, shaded with a very simple volume shader. Details were obtained by just upressing the sim and tweaking the turbulence settings and force lookup ramps. Try using absolute noise when upressing. This might give you some unwanted artifacts but will results in more irregular and fine detail. Cheers Coen Quote Link to comment Share on other sites More sharing options...
Fomal Posted July 5, 2009 Share Posted July 5, 2009 I have another question here.As we see, Pyro has great fire simulation with smoke. How to make Pyro just has its own fire without smoke? Thanks! Don't emit initial density and turn soot to 0 (or deselect the smoke from fire toggle). Now you will sim only the heat. Problem is that mantra needs a density field to render properly (acts as a lookup mask I believe). So by simply renaming heat to density and using that in the shader as the fire name you should be able to only render heat as fire (now density) Also, when doing this make sure the turbscale is being generated from burn+ heat. Since you are not generating any density so no inital force will be applied Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 5, 2009 Share Posted July 5, 2009 I tried to get the Cscatt Layer in rendering but it is allways black, Scattering is on, do I have to do anything else to enable it? Martin Quote Link to comment Share on other sites More sharing options...
Fomal Posted July 5, 2009 Share Posted July 5, 2009 did you render the ,pc files for both fire and smoke? Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 5, 2009 Share Posted July 5, 2009 yep, I did. The Main Image Channel shows scattering effect, too. did you render the ,pc files for both fire and smoke? Quote Link to comment Share on other sites More sharing options...
dbukovec Posted July 5, 2009 Share Posted July 5, 2009 Thanks for the info Coen! Quote Link to comment Share on other sites More sharing options...
dbukovec Posted July 6, 2009 Share Posted July 6, 2009 hi again! Is there any chance for getting that white smoke hip file please? I still have problems, like swimming noise across the smoke and sudden changes in noise pattern. Btw, what You mean on absolute noise? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
JoshJ Posted July 6, 2009 Share Posted July 6, 2009 I second the request for this hip file, was just trying to tweak some white cloudy smoke today without conclusive results... and, I'm also interested to know where the absolute noise option is? hi again!Is there any chance for getting that white smoke hip file please? I still have problems, like swimming noise across the smoke and sudden changes in noise pattern. Btw, what You mean on absolute noise? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Fomal Posted July 7, 2009 Share Posted July 7, 2009 hi again!Is there any chance for getting that white smoke hip file please? I still have problems, like swimming noise across the smoke and sudden changes in noise pattern. Btw, what You mean on absolute noise? Thanks in advance! I'll have to take a look at my backups. Was doing that while I was working on the solver. If I find it I'll post it. Otherwise i'll whip something up. Quote Link to comment Share on other sites More sharing options...
dbukovec Posted July 7, 2009 Share Posted July 7, 2009 thanks a lot! Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted July 7, 2009 Share Posted July 7, 2009 I'll have to take a look at my backups. Was doing that while I was working on the solver. If I find it I'll post it. Otherwise i'll whip something up. Ditto. Once I escape the small production hell I'm currently inhabiting, I'll try to post some of those test scenes. Thanks for covering, Coen, and nice to hear you're still alive out there! Cheers. Quote Link to comment Share on other sites More sharing options...
JoshJ Posted July 7, 2009 Share Posted July 7, 2009 excellent, thanks for your efforts! Ditto. Once I escape the small production hell I'm currently inhabiting, I'll try to post some of those test scenes.Thanks for covering, Coen, and nice to hear you're still alive out there! Cheers. Quote Link to comment Share on other sites More sharing options...
Fomal Posted July 7, 2009 Share Posted July 7, 2009 Ditto. Once I escape the small production hell I'm currently inhabiting, I'll try to post some of those test scenes.Thanks for covering, Coen, and nice to hear you're still alive out there! Cheers. Haha, yes, I am. Settled down and working again. Had a rough and busy couple of weeks over here.But there are still a lot of scenes over at SESI, and I see some requests popping up, regarding specific issues, that can be addressed using those examples.Good luck! Can't wait to see your examples over here as wellCheers! Quote Link to comment Share on other sites More sharing options...
essencevfx Posted July 7, 2009 Share Posted July 7, 2009 excellent, thanks for your efforts! agreed ! Thanks guys these will be a big help to many I'm sure Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 10, 2009 Share Posted July 10, 2009 (edited) Hmm, I finally mangaged to get the scattering layer, but I had to modify the pyro shader for this I added the line Cscatt = Escatt; the export variabke Cscatt was declared but never written. Now it works as expected. Martin Edited July 10, 2009 by sanostol Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted July 10, 2009 Share Posted July 10, 2009 Hmm, I finally mangaged to get the scattering layer, but I had to modify the pyro shader for this I added the line Cscatt = Escatt; the export variabke Cscatt was declared but never written. Now it works as expected. Martin Crap. I guess in that version I called it Escatt instead of Cscatt (it changed a few times). No need to modify the shader, though -- just call the AOV layer (in the ROP) 'Escatt' instead of 'Cscatt'. Apologies for the confusion, Martin. Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 11, 2009 Share Posted July 11, 2009 (edited) No problem What a shader, the scattering looks really beautiful Crap. I guess in that version I called it Escatt instead of Cscatt (it changed a few times). No need to modify the shader, though -- just call the AOV layer (in the ROP) 'Escatt' instead of 'Cscatt'. Apologies for the confusion, Martin. Edited July 11, 2009 by sanostol Quote Link to comment Share on other sites More sharing options...
7697549 Posted July 15, 2009 Share Posted July 15, 2009 Can share your test files? Thank you very much。 I'd like to learn this ,but I am not good at English. Spend a very long time to learning sidefx tutorial . Too many places don't understand. Please help me! Quote Link to comment Share on other sites More sharing options...
essencevfx Posted July 16, 2009 Share Posted July 16, 2009 Hey Mario , thanks for all the info so far. Do you have any tips on getting good noise mapping on the fields, to get that nice 'stringy fire' look . Thanks ! Quote Link to comment Share on other sites More sharing options...
goshone Posted August 14, 2009 Share Posted August 14, 2009 So here is a question... I would like to render fire using the Burn Field instead of the heat field, as I feel it looks better (at least in the viewport) but am unable to produce anything from the Pyro shader when I set the base field to Burn. If I mess with the settings of the interpolation UI, essentially setting it to full on or constant "1", I produce an image that looks identical to the heat field product. Am i missing something? Quote Link to comment Share on other sites More sharing options...
