tomhanks Posted September 15, 2009 Share Posted September 15, 2009 Is there a way to see the object group name's on the viewport just like object names in DOPS? Quote Link to comment Share on other sites More sharing options...
hatrick Posted August 6, 2010 Share Posted August 6, 2010 Is there a way to see the object group name's on the viewport just like object names in DOPS? y would be interesting .... Quote Link to comment Share on other sites More sharing options...
Macha Posted August 6, 2010 Share Posted August 6, 2010 (edited) You can use a pointgrouplist expression in a font sop, perhaps parented to the camera. You can also set attributes according to each group. I sometimes do that and grouping by attribute is a lot faster anyway. But yes, would be nice to see all the groups in the details view... You can of course always middle click on a node, or keep it in an open window when u click the ! button. Perhaps you could also add them as a string attribute and view them that way with the propper names. Edited August 6, 2010 by Macha 1 Quote Link to comment Share on other sites More sharing options...
schiho Posted February 6, 2014 Share Posted February 6, 2014 No Example Files? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 6, 2014 Share Posted February 6, 2014 (edited) Is there a way to see the object group name's on the viewport just like object names in DOPS? You can write SceneHook(or RenderHook if SceneHook is not enough) in HDK or you could probably implement this with inlineCPP in similar manner to this. It should be pretty straightforward. PS. How many people would be interested in this? Edited February 6, 2014 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
anim Posted February 6, 2014 Share Posted February 6, 2014 have look at inspect tool it can show you all groups each primitive belongs to, but only under the cursor, which is enough for most cases http://www.sidefx.com/docs/houdini12.5/basics/inspection Quote Link to comment Share on other sites More sharing options...
