od[forum]: Hou Navigator 0.1 - od[forum]
  • (4 Pages)
  • 1
  • 2
  • 3
  • Last »
  • You cannot start a new topic
  • You cannot reply to this topic
Hou Navigator 0.1 Spacemouse for Houdini
#1 User is offline   FrankFirsching Icon
  • Initiate
  • PipPip
  • Group: Members
  • Name:Frank
  • Firsching
Posted 10 April 2009 - 02:07 PM
Hi all!
Finally I've found some time again to play with Houdini. And the result is something, I'd lilke to share with the community. I've called it "Hou Navigator" and it's a plugin to control the viewport using a 3dconnexion spacemouse. Currently, this is just an alpha release and some paths must be adjusted in the source for it to work, but basic sensor movement is already functional. So, if there's someone who likes to play with it, I'm always happy about feedback.
@Jason: What do you think about adding this to the odforce plugins project on sourceforge?
Cheers and happy Easter!
Frank
Attached File(s)
0
#2 User is offline   DaJuice Icon
  • Houdini Master
  • PipPipPipPip
  • Group: Members
  • Gender:Male
  • Name:Siavash
  • Tehrani
Posted 10 April 2009 - 04:10 PM
Hay, welcome back Frank. :)
I don't have a spacemouse but I'm sure this is good news for a bunch of people.
1) Get 3D software
2) ???
3) Profit!
0
#3 User is online   Jason Icon
  • King Tapir
  • PipPipPipPipPip
  • Group: Admin
  • Gender:Male
  • Name:Jason
  • Iversen
Posted 11 April 2009 - 10:58 PM
This is great, yeah! Well done:) I'll try to get it uploaded to sourceforge.. if I remember how :o
jason iversen
++odforce guy, and supervisor @ r+h
0
#4 User is offline   LFX Icon
  • Peon
  • Pip
  • Group: Members
  • Name:Lorenz
  • Schümann
Posted 22 April 2009 - 02:14 AM
Nice! Waiting for this by SESI. I hope that getting obsolete now, while I help on this with testing.
OK, first prob on installation. Import sysnavigatorPath = "path" leads to an invalid syntax.
I had installed Python 2.5.4 and the SDK 6.0 update for Windows Vista, all 64bit.
Have a nice day
This post has been edited by LFX: 22 April 2009 - 05:45 AM
Lorenz
0
#5 User is offline   FrankFirsching Icon
  • Initiate
  • PipPip
  • Group: Members
  • Name:Frank
  • Firsching
Posted 22 April 2009 - 01:01 PM
First, thanks for testing :-)
Seems you're copy-and-pasting the small python snippet to the python shell, aren't you? It looks like the newline got lost and python is interpreting the two statements as one. In the meantime someone told me, that executing the startup code directly from the python shell results in a crash of houdini. I've added a shelf tool with the startup code and there it's running without problems. I'll have a deeper look into that problem soon. Hope that helps :)
0
#6 User is offline   LFX Icon
  • Peon
  • Pip
  • Group: Members
  • Name:Lorenz
  • Schümann
Posted 24 April 2009 - 11:05 AM
Nope, I just entered this:
>>> import sysnavigatorPath = "C:\Program Files\Side Effects Software\Houdini 9.5.379\spacemouse"
File "<console>", line 1
mouse"
SyntaxError: invalid syntax
But I think, me is missing some basic knowledge of programming. So I'm pretty sure that I miss sth. out in the whole installation process.
This post has been edited by LFX: 24 April 2009 - 11:06 AM
Lorenz
0
#7 User is offline   FrankFirsching Icon
  • Initiate
  • PipPip
  • Group: Members
  • Name:Frank
  • Firsching
Posted 25 April 2009 - 12:33 AM
Ok, the line
is really a syntax error. It should be 2 lines:
import sys
Python is a language, that is very sensitive to line breaks and whitespace characters. As I mentioned in my previous post, unfortunately starting from the interactive python shell doesn't work. Could you please create a new shelf tool and copy the code snippet into the edit field of the "script"-tab in the window that will open? It should look exactly like the example in the readme file concerning the line breaks and indentation.
0
#8 User is offline   LFX Icon
  • Peon
  • Pip
  • Group: Members
  • Name:Lorenz
  • Schümann
Posted 25 April 2009 - 01:36 AM
Done, and no error yet. But nothing happened.
Lorenz
0
#9 User is offline   FrankFirsching Icon
  • Initiate
  • PipPip
  • Group: Members
  • Name:Frank
  • Firsching
Posted 25 April 2009 - 02:37 AM
Is the 3dconnexion driver started? Do you have your mouse pointer placed over a 3D view? The script is moving the camera of the viewer that is placed directly under the mouse. If the mouse is positioned over a different area (e.g. shelf, network pane, etc.) nothing happens.
0
#10 User is offline   LFX Icon
  • Peon
  • Pip
  • Group: Members
  • Name:Lorenz
  • Schümann
Posted 25 April 2009 - 06:23 AM
Yes driver is started. I added a camera and tried to look around.
Only now I added the full code, what I think is right. Like I said before, no clue what's necessary.
import sys
navigatorPath = "[i]Path[/i]"
if not navigatorPath in sys.path:
   sys.path.append(navigatorPath)
import hou_navigator
hou_navigator.start()
And there is coming: No module named spacemouse
Traceback (most recent call last):
  File "tool_2", line 5, in <module>
  File "C:\Program Files\Side Effects Software\Houdini 9.5.379\spacemouse\hou_navigator.py", line 173, in <module>
	import spacemouse
ImportError: No module named spacemouse
This post has been edited by LFX: 25 April 2009 - 06:58 AM
Lorenz
0
#11 User is offline   FrankFirsching Icon
  • Initiate
  • PipPip
  • Group: Members
  • Name:Frank
  • Firsching
Posted 27 April 2009 - 11:04 AM
Did you adapt line 170 (assignment of nativePath) in hou_navigator.py to your installation directory? As far as I can guess it should be
nativePath = "C:/Program Files/Side Effects Software/Houdini 9.5.379/spacemouse/native/build/lib.win32-2.5"
Be sure to use forward slashes (or double backslashes), because certain backslash sequences have a special meaning to python (e.g. \n represents a newline character).
0
#12 User is offline   LFX Icon
  • Peon
  • Pip
  • Group: Members
  • Name:Lorenz
  • Schümann
Posted 27 April 2009 - 11:28 PM
Yeah, that's it! Forward slashes, what a tedious job. You should show the whole path with lib.win32-2.5 in the readme.
Anyway, I'm super happy using the 3D-controller in my favorite app. I stay tuned for any update. Maybe getting full potential of the space pilot someday. :)
Testing it in Houdini 10, too.
Dankeschön
This post has been edited by LFX: 28 April 2009 - 06:04 AM
Lorenz
0
  • (4 Pages)
  • 1
  • 2
  • 3
  • Last »
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
