Build list of a certain type of parameter on a node.
LaidlawFX
I'm trying to build a list of all the parameters of a certain type from a node in python.
For instance for a geo node, I want to build a list of all the toggle parameters on it.
Comparing hou.node('/obj/geo1').asCode() and hou.node('/obj/geo1').parms() was going down a very messy road. I was hoping there was a way to use just the .parms() and check if each parameter is a toggle type?
*Edit
I feel like this may have something to do with it, https://www.sidefx.com/docs/houdini15.5/hom/hou/ToggleParmTemplate
However only when I add a spare parameter and run .asCode() does it seem to reference this, and I can compare against .parms(), but it doesn't work on regular parameters.
Edited by LaidlawFX
Wow F1, only 8 minutes apart.^_^
You can fetch the parm type using code like this.
p = node.parm("parm_test")
pt = p.parmTemplate()
print pt.type()
Or maybe even more scanning of the node like this.
node = hou.pwd()
node_path_to_self = "/obj/pythonscript1"
# Add code to modify contained geometries.
# Use drop down menu to select examples.
lst_types = []
lst_toggles = []
lst_floats = []
def returnParmType(passedParm):
    t = passedParm.parmTemplate().type()
    return str(t)
def addToToggles(node_path,parm_name):
    lst_toggles.append((node_path, parm_name))
def addToFloats(node_path, parm_name):
    lst_floats.append((node_path, parm_name))
for p in node.parms():
    s = returnParmType(p)
    # Also support String, Int, Menu
    if s.find("Float") != -1: addToFloats(node_path_to_self, p.name())
    if s.find("Toggle") != -1: addToToggles(node_path_to_self, p.name())
Edited by Atom
18 minutes ago, f1480187 said:
toggles = [p for p in node.parms() if p.parmTemplate().type() == hou.parmTemplateType.Toggle]
toggles = [p for p in node.parms() if isinstance(p.parmTemplate(), hou.ToggleParmTemplate)]
Not sure which is better.
Your my hero... and don't ever change.
Thanks so much.
*Edit: Atom you can belong in my extended hero universe ;)
Edited by LaidlawFX
Atom
  • 4 years later...
print pt.type()
node = hou.pwd()
lst_types = []
lst_toggles = []
lst_floats = []
    return str(t)
Just what i was looking for! How can you remove parameters??
