Increment value by one on every frame
Sourabh
Hello
I want to increment value by one on every frame after frame no, x (for example 50 frame no.). I tried doing this in wrangle its not working. it stay at one after frame 50.. Its like houdini is reading this script independent on every frame.
Its working in solver node actually but i want to know any other way on sop level.
i tried this ..
if(@Frame>50)
i@a+=1;
Please share with me if you have any way out.
Thank you
Edited by Sourabh
Exactly. You need some sort of simulation context (DOPs, SOP Solver, etc.) if you want to keep data from one frame to the next. But really, a lot of things don't need a simulation context, and then you gain the advantage that you can render your frames out of order.
Thanks all for reply
Both ways are working but my situation was different that i didn't describe properly.I want to increment by one on every frame but for different point number on different frame. Like if random points are turning red on different frame number so increment should start from that frame number for that particular point.
I solve this using wrangle in solver node. I want to know any other way also .
What if you use your points to initialize particles then @age would be the value you want. When a particle is born, it's age is 0.0 then it increments over time from it's random starting time.
Edited by Atom
This still doesn't require a solver context. Your start frame for the given point just becomes a rand() expression (based on the point number) which you then use as an offset on the current frame number.
