Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
art3mis
[novice] Running python script on new session
I have the following script to recursively turn on 'OpenCl' in all my nodes.
First question, how would I run it once, simply paste into a new Python shell or??
2ndquestion, how would I get this to run every time I start a new session?
def set_opencl(parent_node, parm_value):
    for node in parent_node.allSubChildren():
        for p in node.parms():
            if p.name()=='opencl':
                try:
                    p.set(parm_value)
                except hou.PermissionError: #this handles the case that the parm is inside of a locked .otl
                    pass
hou.session.set_opencl(hou.node('/obj/geometry_node_name'),
Share this post
Link to post
There is a mechanism called 123.py which runs when you launch Houdini. I have not used it but you could try searching the help on that.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
