Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
sweetdude09
Computing the Dual With VEX
Hi friends!
I just released an article on Medium walking through how I built a "Compute Dual" wrangle in VEX. As a quick summary, I basically wanted to know how the "Compute Dual" feature of the divide sop worked, so i slapped together a neat lil wrangle, to do just that!
CLICK ME TO GO TO THE ARTICLE!!!!!!!!
Here's a cute little gif showing off the construction of a dual graph. If you like it, please check out the article, it's free and it'd mean the whole world to me! =)
Love you fools,
Jake
http://jakericedesigns.com/
9 people like this
Share this post
Link to post
Yeah this is great. Half edges are a bit of a mystery to me, but this makes them clearer. Thanks!
1 person likes this
Share this post
Link to post
Damn three of my favorite tech wizards all commenting on muh post! :o Thanks for the kind words!!! Another thing I neglected to mention in the post is that the dual of delaunay triangle graph is a voronoi diagram, so really this can also be used as a vex method of generating voronoi diagrams. What that means for us is, assuming you run it on a mesh generated from "Triangulate 2D," you should get a voronoi diagram of the input points! Neat!
Share this post
Link to post
On 20.5.2017 at 2:13 AM, sweetdude09 said:
... the dual of delaunay triangle graph is a voronoi diagram ...
this isn't necessarily true and depends on which type of dual you are using. in case of houdins barycentric based dual for instance, it isn't true. if you wanna get voronoi cells you have to compute the circumcentric (voronoi) dual instead. in this case the dual is orthogonal to it's primal triangulation which is one of the key properties of a voronoi.
dual1.hipnc
1 person likes this
Share this post
Link to post
Ah that's a very interesting distinction. After doing a bit more research it appears i need to compute the dual using the circumcenters of a deluanay triangulation in order to compute the dual. Radical, i might take a crack at that today since I have a bit of free time, will post result in a bit =)
Edited by sweetdude09
I'm a goober!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
