Macha Posted January 25, 2010 Author Share Posted January 25, 2010 Hm. I checked around a little and it appears that threading is not a good option here. Python threads run single-processor and are useful only when one part of the program is waiting for another. As of 2.6 there is a module supporting multicores but that's no good for Houdini-folk yet. At least that's how I understand it. One way of making it faster is to use a different underlying network. Reducing point-neighbors is quite useful and I am experimenting with voronoi patterned surfaces. They give a nice irregular pattern and have less connections than a delaunay mesh (what I use now). I'll have to think about if I and how I could make it more adaptive... Quote Link to comment Share on other sites More sharing options...
Macha Posted January 26, 2010 Author Share Posted January 26, 2010 (edited) In today's update I smoothed moving paths. In the example below the original path is in grey, the smoothed path in red. If start, goal or waypoints nulls are moving then a new path is calculated for every frame. This results in jumping. To alleviate this I: - added a CHOP to blend between the paths of every frame - equalized point numbers along these paths - applied another CHOP to the mouse's path travel in order to smooth any jumps resulting from sudden path stretching (it can chance spacing between the NURB points) (The tip of the path is trailing but that's just an aesthetic decision and I could have kept it stuck to the moving goal.) Edited January 26, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
edward Posted February 1, 2010 Share Posted February 1, 2010 I've just been only casually paying attention. Does VEX/VOPs help with any of this? Esp. if you want multi-threading. Quote Link to comment Share on other sites More sharing options...
Macha Posted February 1, 2010 Author Share Posted February 1, 2010 I've just been only casually paying attention. Does VEX/VOPs help with any of this? Esp. if you want multi-threading. Well, it was an exercise to learn Python so I tried to avoid vex. But now at this stage I'm thinking it could be useful. Do you know if it is possible to call VEX from inside Python? I know I can access Hscript via hou.hscriptExpression. If that was possible with vex, there could be useful functions for this. Quote Link to comment Share on other sites More sharing options...
graham Posted February 1, 2010 Share Posted February 1, 2010 There's currently no way to call VEX code from within Python. Quote Link to comment Share on other sites More sharing options...
Macha Posted March 29, 2010 Author Share Posted March 29, 2010 (edited) I have improved speed quite a lot with this recently by adding vex code to calculate neighbors and an improved path finding algorithm. The bottleneck is the neighbour calculation. It becomes very slow over 3000 points (15 seconds perhaps). I also noticed that vex doesn't multithread, even though it is often said to do so. Luckily the neighbours do only have to be calculated once per geometry. Below are stats for the pathfinding for a scene with 3 waypoints. number of points 100 number of edges 180 Time: 0.0149998664856 seconds number of points 400 number of edges 760 Time: 0.108999967575 seconds number of points 900 number of edges 1740 Time: 0.266000032425 seconds number of points 1600 number of edges 3120 Time: 0.655999898911 seconds number of points 2500 number of edges 4900 Time: 1.39100003242 seconds number of points 3600 number of edges 7080 Time: 2.42200016975 seconds Edited March 29, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted March 30, 2010 Author Share Posted March 30, 2010 In the image below I have used a different algorithm. It is not the shortest path that is calculated here but just a path (but still a short one). This results in a much faster calculation. So fast in fact that it spits out several hundred paths at once in less than a second. Here they spawn from points across the sphere and converge to a common target. The bottleneck here is neither the neighbour calculation, nor the path finding but the mesh generation of the wires, by an order of magnitude! All paths 973 Time: 0.296999931335 seconds Video: Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted March 30, 2010 Share Posted March 30, 2010 In the image below I have used a different algorithm. macha you should be my houdini teacher, how much do you want to teachme? Quote Link to comment Share on other sites More sharing options...
Macha Posted March 30, 2010 Author Share Posted March 30, 2010 I can make some rather cool veins stuff with those paths! Quote Link to comment Share on other sites More sharing options...
eetu Posted March 30, 2010 Share Posted March 30, 2010 (edited) I can make some rather cool veins stuff with those paths! So you can! An update from Macha makes for a better day. Edited March 30, 2010 by eetu Quote Link to comment Share on other sites More sharing options...
wigal123 Posted March 30, 2010 Share Posted March 30, 2010 cool stuff! time to share some code Quote Link to comment Share on other sites More sharing options...
mightcouldb1 Posted March 30, 2010 Share Posted March 30, 2010 (edited) This looks great. Care to share the theory behind it? Edited March 30, 2010 by mightcouldb1 Quote Link to comment Share on other sites More sharing options...
Macha Posted March 30, 2010 Author Share Posted March 30, 2010 Maybe if I get it clean and neat one day I can share the code but for the moment it is too much like a home-build machine that needs a drop of oil in the right place every now and then, or a piece of string wrapped around a pipe here and there. As for the most recent one, the idea behind it is to calculate all the paths at once (very fast though because real euclidian distances are disregarded, only path-steps are counted), write them out to a file dictionary, and then sample from that dictionary, loop through it, and build paths. As a pre-step I also mess up the point positions via sop network, while keeping the shape, otherwise the paths are too regular and look like a pattern. Quote Link to comment Share on other sites More sharing options...
Macha Posted March 31, 2010 Author Share Posted March 31, 2010 New video here: 1 Quote Link to comment Share on other sites More sharing options...
Macha Posted April 6, 2010 Author Share Posted April 6, 2010 (edited) Mouse has gone to space to chase cheese planets. So, she can now hop randomly through a cloudpoint, avoiding her own path, but still getting to the cheese relatively quickly. I suppose this could be called a targeted self-avoiding Brownian path. She can interpolate the paths between the points of the cloud, so she makes straighter paths. Video: Edited April 6, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Macha Posted April 6, 2010 Author Share Posted April 6, 2010 (edited) The same as before but prettier. Not all the points in the cloud are visited (small spheres). Just those that lead from start to goal. Video: Edited April 6, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Nerox Posted July 7, 2011 Share Posted July 7, 2011 (edited) Hi Marc! Wow, I find this totally awesome :-D. As an exercise I'm building a similair system using A*. I wonder how did you go about storing the neighbour information? You can use vops to get the neighbours, but where do you store it? All I can think of is creating an x number of attributes on each point which you can use to store neighbor point numbers. I wonder if this is the best way to do this, since I fear that it will create a lot of overhead in terms of memory, I mean how many neighbors are you going to support? It's to bad that Python appears to get slow when going over connected neigbors, since if you could compute it on the fly you would never have to touch points you aren't going to visit anyway. Especially with highly detailed maps it would make a huge difference I guess. What's your opinion on this? Edited July 7, 2011 by Nerox Quote Link to comment Share on other sites More sharing options...
