rony Posted May 17, 2012 Author Share Posted May 17, 2012 For today's wisps test I give you a spaghetti volume Plus I've added motion blur calculation into the density itself instead of vel.(xyz). Quote Link to comment Share on other sites More sharing options...
Netvudu Posted May 17, 2012 Share Posted May 17, 2012 It's on my website for Linux. ah, ok. I can only use Win64 for my personal stuff, but it´s only logical that you work it on Linux. Maybe there will be a Windows version when it´s finished? Quote Link to comment Share on other sites More sharing options...
rony Posted May 18, 2012 Author Share Posted May 18, 2012 ah, ok. I can only use Win64 for my personal stuff, but it´s only logical that you work it on Linux. Maybe there will be a Windows version when it´s finished? The reason why I am not supporting windows anymore is because Sidefx switched to Visual Studio 2008 (VC9) to compile Houdini 12. I only have Visual Studio 2005 (VC8). The express edition only compiles 32 bit code so for the time being I'm putting it on hold. Cheers, Ron Quote Link to comment Share on other sites More sharing options...
rony Posted July 10, 2012 Author Share Posted July 10, 2012 (edited) It's been a while since I've posted anything and since I just bought an HD non commercial license I decided to give it a shot. Here are 2 images rendered in high res of a surface wisps volume. The resolution is 1000x1000x500. The first is saved with alpha, the second, without. Cheers, Ron Edited July 10, 2012 by rony Quote Link to comment Share on other sites More sharing options...
rony Posted May 20, 2013 Author Share Posted May 20, 2013 I've released a new version of the plugins for Houdini 12.5. Here's the link: http://www.3dde.com/plugins_page.html I've added support for GIF files and modified the watermark to randomized scanlines. It's not pretty and will flicker but it's more discreet than the previous watermark. This is compiled with GCC-4.6.2 using Houdini12.5.376 so make sure you have the compatible version of Houdini and GCC installed. Also the windows 7 version is on its way soon. I'll post it once ready. Enjoy. Cheers, Ron Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted May 20, 2013 Share Posted May 20, 2013 (edited) The reason why I am not supporting windows anymore is because Sidefx switched to Visual Studio 2008 (VC9) to compile Houdini 12. I only have Visual Studio 2005 (VC8). The express edition only compiles 32 bit code so for the time being I'm putting it on hold. Cheers, Ron Windows SDK contains free 64-bit MS C++ compiler. For VS2008 version get older SDK. I think it's this one. Good source of info about SDK's is here. PS. It looks also that you can force 2008 Express Edition to use SDK 64 bit compiler. Probably a little pain in the ass to setup but it may work. PS2. For all you out there that would like to use inlineCPP on Windows and can't right now, you should try this SDK because it looks that it's all you need to make it work if you don't have VS2008. PS3. I think Code::Blocks can use MS Compiler if it detects it. Maybe someone could try to make it work with SDK and compile for Houdini. Someone with free time. Edited May 20, 2013 by mantragora Quote Link to comment Share on other sites More sharing options...
rony Posted May 27, 2013 Author Share Posted May 27, 2013 I've released the plug-ins for Windows 7 64 bit. There is no licensing scheme yet so you'll get randomized flickering scanlines but the plugins themselves work fine. Let me know if you find a bug. I'll post a hip file that uses all the plug-ins so that you can get an idea on how to set up a workflow with the correct attributes etc. You can find them at the same page: http://www.3dde.com/plugins_page.html Enjoy! Cheers, Ron Quote Link to comment Share on other sites More sharing options...
Netvudu Posted May 27, 2013 Share Posted May 27, 2013 Will you release a free non-commercial version of this, or will it be solely a paid solution? Quote Link to comment Share on other sites More sharing options...
cosku Posted May 28, 2013 Share Posted May 28, 2013 In case anyone is trying to get a render going, you need to feed it points with: * Cd (non-black) * density (non-zero) * pscale (non-zero) Any ideas about the final price range? Quote Link to comment Share on other sites More sharing options...
rony Posted May 30, 2013 Author Share Posted May 30, 2013 There was a multi-threaded clouds plug-in missing from the Linux distro, so I've added it to the 12.5 download. I've also added a hip file with descriptions and examples demonstrating how to set up the different workflows to use the plugins. The flickering watermark is still there but you can see what the workflow consists of. Again all can be found here: http://www.3dde.com/plugins_page.html Enjoy. PS: @Netvudu. The flickering watermark is part of the non commercial solution. Quote Link to comment Share on other sites More sharing options...
rony Posted June 15, 2013 Author Share Posted June 15, 2013 Here's another surface wisps test: https://vimeo.com/68414622 And the hip file: http://www.3dde.com/hip/pulsar_test_sw_1.hipnc Enjoy. Cheers, Ron Quote Link to comment Share on other sites More sharing options...
ice_cat Posted June 20, 2013 Share Posted June 20, 2013 Why can not I download the hip file, you can send me mail it, thank you,59989592@qq.com Quote Link to comment Share on other sites More sharing options...
rony Posted June 26, 2013 Author Share Posted June 26, 2013 Hi Ice_cat. Sorry about the late reply. You can download the hipnc file by right-clicking on the link and selecting save-as. You can do this here or got to the website and right-click on Download Example Hip File and save-as: http://www.3dde.com/plugins_page.html Let me know if that doesn't work. Cheers, Ron Quote Link to comment Share on other sites More sharing options...
rony Posted October 2, 2014 Author Share Posted October 2, 2014 So after a long period of inactivity. I've decided to release the latest updates and include the versions of the plug-ins for free. You can now download them here: http://www.3dde.com/plugins_page.html No more watermarks or license files. Enjoy! Cheers, Ron 2 Quote Link to comment Share on other sites More sharing options...
eetu Posted October 2, 2014 Share Posted October 2, 2014 Awesome, thanks! Quote Link to comment Share on other sites More sharing options...
kleer001 Posted October 2, 2014 Share Posted October 2, 2014 (edited) Wow, that looks amazing. Thanks Rony! Any chance of getting a Mac OsX compile? Edited October 2, 2014 by kleer001 Quote Link to comment Share on other sites More sharing options...
