ehsan parizi Posted September 6, 2011 Share Posted September 6, 2011 Hi all, I have 2 questions : 1. Why can't we see face (primitive) normals as an attribute on the details view? 2. How can I change that normal? I know how to manipulate my point normals, but I don't know how to do the same thing with primitive normals? I thought maybe primitive sop can do it, but apparently I was wrong! I appreciate your help in advance. Quote Link to comment Share on other sites More sharing options...
graham Posted September 7, 2011 Share Posted September 7, 2011 Primitive normals are not actually an attribute. They are derived information that is calculated based upon the vertices that make up the primitive. As such, they cannot be modified. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 7, 2011 Author Share Posted September 7, 2011 you mean if my geometry has screwed up Primitive normals, basically there's no way to fix it?! Quote Link to comment Share on other sites More sharing options...
tjeeds Posted September 7, 2011 Share Posted September 7, 2011 Sure there is, you just have to fix the geometry, not the normals. How are they screwed up? If they are facign the wrong direction the Reverse sop will flip the vertex order around, also the Facet Sop has an orient polygons toggle which can help if you have a mixture of correct and inverted faces. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 7, 2011 Author Share Posted September 7, 2011 also the Facet Sop has an orient polygons toggle which can help if you have a mixture of correct and inverted faces. That's exactly the case. there are just a few primitives facing backwards! I tried the Orient Polygons in the Fact Sop, but it didn't work out! Quote Link to comment Share on other sites More sharing options...
anim Posted September 7, 2011 Share Posted September 7, 2011 Orient Polygons works if the primitives with mixed normals are connected together it will make sure that normal orientation is continuous over all polygons in each connected geometry piece and it takes first polygon of each piece as a direction reference so if they seem to be connected and it's not working you may try to use Fuse SOP before or if there are whole connected pieces that have inverted normals you may consider Assemble SOP to create groups from connected pieces and Reverse SOP on groups you want to invert but if you already have point N attribute you may also check Post-Compute Normals on the same Facet SOP to update them if you have vertex N atttribute you may need to delete it (attribute SOP delete parm) and create new one with Vertex SOP after orienting polygons (instead of using Post-Compute Normals which would create point N) Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 7, 2011 Author Share Posted September 7, 2011 Thank you guys. Well, it was actually just a few bad primitives, the problem was actually not the normals, it was the topology, it was a bit messy model, but very simple, so I just fixed those primitives by some point editing points. But I learned some new stuff anyway. Thanks again 1 Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted September 7, 2011 Author Share Posted September 7, 2011 here's another question, which is kinda relative : Can we read the primitive's N to make an attribute based on it! I tried, but looks like it's either impossible, OR it's not called $NX,Y and Z! Quote Link to comment Share on other sites More sharing options...
anim Posted September 7, 2011 Share Posted September 7, 2011 (edited) as it's been told ptimitive normal is not an attribute so it cannot be accessed by $N* but if you have you custom primitive N attribute it can, but that will not be used as normal for shading to base something on primitive normal you can do following Initial Geometry | Facet SOP (unique points, post compute N) | Attribute Create (primitive N float3, value: $NX, $NY, $NZ) this will use average of point N from Facet SOP to set primitive N and since all points are unique, that N should be equal to primitive normal then just Attribute Copy your primitive N attribute to your Initial Geometry and you can use it for whatever you want or just use above Attribute Create and Copy to create other attribute based on $N* directly Edited September 7, 2011 by anim Quote Link to comment Share on other sites More sharing options...
petz Posted September 8, 2011 Share Posted September 8, 2011 can´t you use just the prim-expression for that? petz Quote Link to comment Share on other sites More sharing options...
anim Posted September 8, 2011 Share Posted September 8, 2011 can´t you use just the prim-expression for that? petz I guess you can, sorry for overcomplicating things so just do as petz said Attrib Create primitive vector attribute and values to prim(opinputpath(".",0),$PR, "N", 0 ) Quote Link to comment Share on other sites More sharing options...
kamilosmuczaczos Posted February 4, 2018 Share Posted February 4, 2018 Hi guys, I see that you already discussed that topic but unfortunately I am still struggling to overcome my problem. There is only one primitive which is faceing wrong direction. Its primitive with number 1800 which was created with sweep node (I attached file). I'm very new to houdini so I was wondering if it is possible to overcome without using VEX and creating new attribute ( maybe I made some mistakes before while creating curve). Is there any way to change its orientation to (0,-1,0) ? procedural_tube_uv.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 5, 2018 Share Posted February 5, 2018 add a reverse Sop and your primitive 0. procedural_tube_uv.hip 2 Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted February 7, 2018 Share Posted February 7, 2018 Use the "Normal" sop, set it to primitives and then you have your normals on primitives, and it can be seen in the spreadsheet. Quote Link to comment Share on other sites More sharing options...
