Primitive Sort
renderfan
I have geometry from other programm that i use in houdini. The problem is wrong numbering of primitives because i must use Foreach-SOP on primitives in order. Is there some way i can reorder the primitives. I have tried Sort-SOP but can not get right order.
Thank you in advance!
Try with sort SOP. in sort SOP you can see primitive tab. change primitive sort parameter.
