How to group the whole connected primitives using Bounding Object?
I have some temporary objects (boxes) which I use as a Bounding Object for a Group SOP where I want to select the whole connected spheres if any of the points are selected in the Group.
After selecting these points, converting them to prims in the Group still doesn't select the whole connected object.
How can I achieve this?
Thanks guys.
@Macha, I am not sure how do you mean merge the boxes? They are a single object as well, created using the Copy SOP.
@papicrunch, near trick, that seems to work. Didn't think it would be this involved but still clever :)
If anyone has other ways to do this, I would like to know.
Hi, another method is that this group you created is your preselect group, so lets assume to call it preselect.
Now put down another group sop, set it to points, turn off the enable toggle on the first page, go to edge tab, turn it on.
Turn on edge depth, and in the points group field choose your preselect group, then adjust your edge depth accordingly.
I use this all the time.
  • Like 3
  • Thanks 1
  • 14 years later...
we are in 2026 and this help a lot !
