Flip Fluid Waterfall tutorial
cool robert.magee
These tutorials are really making the edge.
mikey madrid
Just a little update, went up to minute 25 ROP out the sim (it´s later here in madrid)
Scott Keating, really clear explanation. it make things so easy now.
cheers
mikey
cheers
mikey
Update_Complete
Just wanted to make some comments about Scott´s Tutorial.
Really clear explanations on each step.
In the VOP´s he actually explains what he is doing , Not just connecting nodes, (compared to CMIVFX "it was really hard to understabd that instructor" I think he was from india) Houdini Fluid Effects For TD's
Looking forward for more tutorials Scott
cheers
mikey
Edited by mangi
Really great tutorial! Thanks SESI for posting.
Might be a dumb question but...
I was wonder why all of the foam/spray stuff was done in dops with a pop solver instead of just done in a popnet?
~Zach
This is equivalent solution + free caching and easy collisions handling available in DOPs.
@00:46:48 : should that not be $NPT*24 instead ?
That would probably do the job. While recording the tutorial, I had a little bit of a brain-drift. I had actually meant to use the npoints expression in the impulse activation rather than the constant birthrate. That said, it isn't actually necessary to match the number of points to the number of points emitted in the spray sim, but I found it gave the nicest results.
Hope this helps!
-Keating
Keating.
I just did the the tutorial a second time . Just to get a really good feel.
I see that the tutorial file that was uploaded has nothing to do with the render that
was made.
It would have been really cool to have that file.
Can you take this Flip Fluid Waterfall tutorial into a bit of shading.
Cheers mikey
Edited by mangi
Keating.
was made.
Cheers mikey
The final rendered file had quite a large number of particles and would have required a very large download file. We will be handling the lighting and rendering of the scene in a separate tutorial ( coming soon! )
Glad you liked the tutorial!
-Keating
-Keating
Cool Great . looking forward to this
take care mikey
Hello,
want to make sure i'm understanding the tutorial correctly, the voppop is making the inside particles move to the closest surface - particles falling through under the surface field is because they were closer to the bottom surface? If yes, is it not possible to make all particles go on top? Oo"
eitht.
it was sooo easy to follow and understand . perfect !
thank you SESI for uploading this !!
hope to see more for other contexts too ( not only simulations ) ..
.cheers
~Zach
Sorry, I hadn't noticed this question earlier.
I used a pop solver inside of a pop net for a couple of reasons. Mostly, I prefer the workflow because it gives free caching/scrubbing of the timeline which is helpful when you're really trying to make sure an effect is doing what you hope its doing. More importantly, the dopnet allows you to very easily add collision objects which are more accurate than the ones using a collision pop inside a popnet. I used a very simple landscape in the tutorial, but in in theory you could have many collisions objects with varying detail.
Hope that answers your question!
Thanks for watching,
-Keating
