toadstorm
melting a textured object with FLIPs
Hello,
I'm trying to figure out how to melt an object using FLIP fluids and have the UVs melt with the object. Getting the fluid motion down isn't a big problem, but I can't get the UVs to follow along. I played around with creating a vector field based on the source object's UVs in the hopes that I could advect it in DOPs, but I can't even get the UVs to write correctly to a vector field. I also tried using an attribTransfer node to transfer the UVs from the original geo to the points created by the Fluid Source node, and then I again transfer the UVs from the imported fluid particles (in SOPs, from the Dop I/O) onto the particle fluid surface, which kind of works, but the UV seams are always incredibly distorted because I have to convert the UVs from a vertex attribute to a point attribute.
Is there a better approach to this? I know I've seen this done in Houdini but I can't find any good information on how it's done.
Thanks!
Edited by galakgorr
Share this post
Link to post
attr Transfer uv's to particles....sim....and attr transfer back to mesh at end...I have had sucess with this....you can also use different layers of uvs for this
Share this post
Link to post
Hiya galakgorr
Sorry for the short reply but I sent it from my phone....
I have attached a scene which is one simple approach..
By using different nested geo's with different uvs all sorts of layered textured effects are possible..
Hope this help
Spev
flipUV_v001.hipnc
  • Like 3
Share this post
Link to post
Thanks so much for the reply, spev!
I eventually came up with a similar solution, but I used a Fluid Source node and then transferred the UVs from the original object onto the points created by the Fluid Source, then did the same thing you did in the Particle Fluid Surface node to bring the UV attributes back onto the geometry. The only consistent issue is the UV distortion at the seams of the object, but I guess there isn't really a way to avoid that.
Again, thanks for the example scene!
Edited by galakgorr
Share this post
Link to post
Is there any way to remove the seam, I increased the point counts but not working. I used 800000 points need help please
post-6051-0-64559300-1417978077_thumb.pn
Share this post
Link to post
I am having this Seams, problems as well.
Have you got any idea on this problem yet?
post-13240-0-18891300-1449497789_thumb.j
Share this post
Link to post
Have you tried turning on the check box for Fix Boundary Seams of the UV Texture node?
post-12295-0-02172900-1449508700_thumb.j
Edited by Atom
Share this post
Link to post
the seams come from converting your vertex uvs to point uvs.  your sim is inherently point-based, so you're losing data right away.  you might try using the rest position of your sim to access the original clean uv's from your model and see if you can avoid the seams.  i'd look at trying to grab the data using the closest point point the surface and then pulling in the uv from the vertices on the hit position.
Share this post
Link to post
Hi Atom,
Thanks for the hint.
I am transfering my vertex UV to point UV, so I didn't place another UV texture node there.
So I not sure if it's that problem.
Share this post
Link to post
Hi Fathom,
yea. that's the problem I having how.
I didn't use any rest node before. Do you means the rest position is something like start frame of my sim?
But I have already do the uv convert process, doesn't it give same outcome?
I did some checking on my uv convert on both vertex and point, they look the same and i check the point from volumn colour, It didn't show the seams,.
I am guessing some how it's the uv transfer back to mesh problem.
Share this post
Link to post
Any solutions to this?
I see its possible, but im not sure how??
https://vimeo.com/113844471
The guy said he'd post a breakdown, but has yet to.
The biggest clue is
"my source was points from volume after i set my source i attribtransfer ( uv) from my obj to this source
after the meshing again i transfer uv and v from my cached file But a lil note in this attrib transfer my
max sample count =2000"
But im not sure what he means, maybe someone here could extrapolate?
Share this post
Link to post
Here's an example that kinda works.
Sorry, it may be slow to compute my test file, I needed a lot of points to have a "correct" result.
And I'm basically treating each non connected UV as a "separate" fluid, couldn't think about any other way.
I did not change any setting in the FLIP (just the separation)
flip_conserveuv.hipnc
  • Thanks 1
Share this post
Link to post
Yeah it's a little slow, but the result is pretty good! Thing is my model has an ugly uv layout, prob would need 20 or so separate objects haha. There must be a way around this? Guy who's video I sent said there were no issues with seams.
The way ive done it is choosing 'surface sop' for the flip solvers initial data type, which keeps all UVs but behaves a lot differently because obviously it just computes the surface of the object (no fills). I just bought a flip tutorial set from luxx, need to go through it and ill report back.
Think I'll sort out my UVs too!
Edited by jim_johnston
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
