why i get black refractions in this image?
hi, i dont know why im getting black refractions in this image, the dropplets and the sphere is a mantra surface, looks like the problem is with objects with refractions making contact with other surfaces and the logo on the left is a mantra surface with thin film refractions, so i have this problem only with common refractions, which could be the problem?
Edited by dyei nightmare
Just a shot in the dark, but what is your refraction limit in your mantra > shading tab ? Do you have any attenuation set in your material, are you using pbr ?
yes, the refraction and reflection limits are 10, in pbr, no atenuation, i found that shadows was causing little of it... and switched to glass material, but there is still some thing messing around.
jabon.hip
