mrcain Posted July 24, 2013 Share Posted July 24, 2013 Hi, Trying to export the cloud rig generated in h12.5 to maya. Apparently alembic and fbx doesn't work. Does anyone know another way? Cheers Quote Link to comment Share on other sites More sharing options...
kleer001 Posted July 25, 2013 Share Posted July 25, 2013 Do you mean the volume field and associated shader? I don't think that's going to work. Why would you need it in Maya? You're going to have an easier time exporting stuff from Maya into Houdini, using it as a mask and rendering it that way than getting volumes from Houdini into Maya (if that's even possible). Quote Link to comment Share on other sites More sharing options...
edward Posted July 29, 2013 Share Posted July 29, 2013 As far as I know, neither Alembic nor FBX currently supports volumes. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted July 29, 2013 Share Posted July 29, 2013 (edited) In my opinion the cloud rig depends on too many things in Houdini to be of any use in another application like Maya. You'd basically have to rewrite 99% of it in Maya to make use of the data. You could get just the volume information to Maya with OpenVDB but it wouldn't be very useful compared to all the bells and whistles provided in Houdini (cloud light node, volume shaders, procedural noise, etc.). If you can just render the clouds in Houdini and save yourself the headache. EDIT: Maybe not, I can't find anything on Maya for OpenVDB. Another format to consider is Field3D which has third party plugin for Maya. Edited July 29, 2013 by lukeiamyourfather Quote Link to comment Share on other sites More sharing options...
mrcain Posted July 29, 2013 Author Share Posted July 29, 2013 Thanks for the responses. We went the field3d route. Need it in maya as part of the pipeline. Openvdn isnt available until later in the year for Maya. Cheers! Kistaan Quote Link to comment Share on other sites More sharing options...
