setting noise range by ramp vopsop
HI, Guys.
I am going to curlnoise a grid.
I hope i can control the range of noise,also the strength of the curlnoise can decrease slowly,just like gradual change.
So the ramp must be best.
It looks a little easy, but i fail when try vopsop, i just have not grasp the essence of the vopsop.
I make a simple sketch, hope you guys can understand.
Many thanks!
post-9982-0-08773300-1378763092_thumb.jp
NOISE_Ramp.hip
From your image I think this is what you meant. It might not be the most efficient way of doing it but I think it's quite close.
If you want to effect the noise in the other axes plug them through another mult node.
If there's anything you don't understand just ask.
NOISE_Ramp_minMax.hip
Edited by Mumble
Exactly what I wanted!
More controllable,
I will take a look carefully!
Thank you, Tobin !
