anyway to use oceanwave deform in vopsop?
Because i want to control the range of the wave, so i did it in vopsop.
But there is no such a oceanwave deform in vopsop.
However i can replace the houdini oceanwave by HOT ocean in vopsop, but it is a little slowly.
Anyway can i use the houdini oceanwave in vopsop, or other way to control the range of the oceanwave.
a simple sketch.
Thank you for your time!
post-9982-0-36640700-1380265453_thumb.jp
Do this:
1. Create a point attribute: ex in_range. set 1 = inside the range and 0outside the range
2. Use the ocean wave deformation
3. Create a vopsop and apply the grid(non-deformed) to the first input and the deformed to the second input. Now you simply need to apply the position of the deformed to those points with the attribute in_range =1
4. You should also build up a way to smooth the edges. let's say make the attribute in_range to a float between 0-1 and you could use a mixVOP and set the attribute to the bias.
You could do the same operation for all attributes you need from the ocean deform
  On 9/27/2013 at 8:42 AM, Hudson said:
Do this:
Hudson.
Thanks you for your reply!
Anyway i create a basic vopsop follow your advice.
It is useful !
But i am a bit stupid when build the smooth edges. I get a issue.
Are you convenient to check my HIP,or give me a simple sketch.
Thanks again!
Edited by wateryfield
Do this:
sorry. forget the HIP.
VOPSOP_range.hipncFetching info...
