-nöm- Posted December 6, 2013 Share Posted December 6, 2013 (edited) I'm building a crowd simulation system by creating custom VEX operators being cooked in a SOP simulation. Along with implementing basic behaviours(arrive,separation,cohesion,alignment,obstacle-avoidance,wander,leader following etc.) by manipulating point positions being accessed from the amazing Houdini point cloud feature, I'm working on a path-following behaviour. I'd like the user to be able to define his own path, a curve rather(as I'm using a curve to define a path), is there anyway I can make my digital asset user-driven, wherein the user can have an option to simply draw up the curve on the grid? If I found nothing, I would let the user load up an image file with a path drawn on it, and let that form the path to be followed, but I'd have to somehow scatter points(after tracing it) in such a way that they form path-like connected line-segments(even if they might not be curves, it'll still work if I can simply get to access the points forming the line-segments of the path). But I'm sure someone can come up with a far better solution than that, really looking forward to it! (It's eating the insides of my brain now!!) Thanks! Cheers Edited December 6, 2013 by -nöm- Quote Link to comment Share on other sites More sharing options...
dpap Posted December 6, 2013 Share Posted December 6, 2013 Hi nom! Are you looking for this? It's a new feature in H13! http://www.sidefx.com/docs/houdini13.0/shelf/drawcurve Quote Link to comment Share on other sites More sharing options...
-nöm- Posted December 6, 2013 Author Share Posted December 6, 2013 (edited) Yes, kinda! But how do I assign this tool to the interface of my digital asset, in such a way that any 'user' using my digital asset will be able to draw the curve and the curve will automatically get connected to the node I want it to, once it has been created (by the user) ? I'd like the curve/path to be user-driven, rather than me defining the curves and packaging the whole as an asset. Edited December 6, 2013 by -nöm- Quote Link to comment Share on other sites More sharing options...
mawi Posted December 6, 2013 Share Posted December 6, 2013 (edited) On 12/6/2013 at 6:10 PM, -nöm- said: Yes, kinda! But how do I assign this tool to the interface of my digital asset, in such a way that once any 'user' using my digital asset will be able to draw the curve and the curve will automatically get connected to the node I want it to, once it has been created (by the user) ? I'd like the curve/path to be user-driven, rather than me defining the curves and packaging the whole as an asset. Let the user paint curves outside of the asset and then use a objectmerge SOP with a promoted objectpath to bring it into the HDA. 1. Its easy to implement. 2. The user might want to use a curve generated some other way. Edited December 6, 2013 by mawi Quote Link to comment Share on other sites More sharing options...
-nöm- Posted December 7, 2013 Author Share Posted December 7, 2013 That does sound like a basic reasonable solution, yes. Thanks man! Quote Link to comment Share on other sites More sharing options...
anim Posted December 10, 2013 Share Posted December 10, 2013 Draw Curve SOP is just an asset using Stroke SOP inside to draw curves, you can do the same, just use Stroke SOP inside of your asset an promote Number of Strokes (stroke_numstrokes) multiparm to your asset then type stroke into Type Properties/Basic/Default State field on your asset, that's it or you can even package Draw Curve SOP in your asset instead of just Stroke SOP (and promote the same multiparm and use stroke as default state as well) 1 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 9, 2015 Share Posted June 9, 2015 Any chance to promote Paint SOP for example? Quote Link to comment Share on other sites More sharing options...
