jonathantopf Posted March 25, 2014 Share Posted March 25, 2014 Hi there, I'm trying to create a bundle of wires and cant find a way thats quite satisfactory. I have found lots of ways but they all end up with intersecting geometry. What I'm doing currently is doing a scatter over a circle and copying random sized circles over the scattered point and extruding that, bviuosly this leads to intersecting geo. I jut cant think of a way to create points that tesselate properly. With that in mind how would anyone go about creating a cross section like this to extrude? Thanks! Quote Link to comment Share on other sites More sharing options...
eetu Posted March 25, 2014 Share Posted March 25, 2014 A fun challenge Here is one method with voronoi + dual: Another, maybe better, idea would be to check the distance to the closest point, and use that as the radius for the point to copied. ee_circlepack.hipFetching info... 3 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 25, 2014 Share Posted March 25, 2014 Not as good as Eetu's but I wanted to give it a try and made 2 different variations Also is there a way to use Houdini's voronoi tools to split a model but keep the parts fused? I know you can use the Fuse SOP, but for complex shapes after using voronoi, it doesn't work well, so you either fuse more than you want or have holes. scatter.hipFetching info... 2 Quote Link to comment Share on other sites More sharing options...
eetu Posted March 25, 2014 Share Posted March 25, 2014 If it's ok to be regular, you could go the good old phyllotaxis route ee_phyllodiscs.hipFetching info... 2 Quote Link to comment Share on other sites More sharing options...
dpap Posted March 25, 2014 Share Posted March 25, 2014 @Magneto Any reason you used scatter +copy to get 500,000 point instead of just setting the scatter sop to 500,000 point? Any advantages this way? Just curious.. Can anyone make it perfectly symettrical/ ordered? Something like this but more procedural... I know I should use a Copy sop at he begining but I stamping a value at the radious didn't work. I am doing something wrong obviously... ordered.hipFetching info... Quote Link to comment Share on other sites More sharing options...
magneto Posted March 25, 2014 Share Posted March 25, 2014 (edited) The only reason was to get a bit more "chaotic" distribution If you just use a single Scatter SOP, then it pretty much covers everywhere evenly with a very high number of points, which is why the second pic has circles that are a lot more uniform in radius. Edited March 25, 2014 by magneto Quote Link to comment Share on other sites More sharing options...
dpap Posted March 25, 2014 Share Posted March 25, 2014 @ Magneto Cool approach! I wish the same functionality was part of the Scatter sop! Useless info of the day: Modo actually implements something like in its " Replicators" so that Replicas don't get on top of each other... 1 Quote Link to comment Share on other sites More sharing options...
jonathantopf Posted March 26, 2014 Author Share Posted March 26, 2014 (edited) Wow so many responses! I invented another solution also as i realised I ddint need all the circles in the center as the whole thing wold be extruded: Heres my workflow: Create circle Scatter points on circle Sort points radially using expression: atan2($TY, $TX) using a vop sop work out the distance between each point and its clockwise neigbour, add a radius attribute thats 1/2 that distance, then move current the points position in the vop sop to the center point between the itetrating point and it clockwise neigbour. use a copy sop to copy circles to each point and stamp the radius value to the circles radius Hope that makes sense! I actually think some of the answers above look nicer but my solution is ligher on the geo so imgoign with that for now, thanks for all the responses! Edited March 26, 2014 by jonathantopf Quote Link to comment Share on other sites More sharing options...
vinyvince Posted July 16, 2020 Share Posted July 16, 2020 On 3/25/2014 at 1:58 PM, eetu said: A fun challenge Here is one method with voronoi + dual: Another, maybe better, idea would be to check the distance to the closest point, and use that as the radius for the point to copied. ee_circlepack.hipFetching info... Expand Im tunning this neat old little trick in h18, but not circle are copied to every point, can't see the reason and will be curious to know why? v* Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted July 16, 2020 Share Posted July 16, 2020 (edited) Hi, it works for me, if I turn on "Minimum Distance" method instead of "Project Rays" in the ray sop. btw: if you take the idea using the closest distance as radius, you can calculate the greatest radius of each circle, which has the prim centroid as center an touching at least one line of the primitive (but without overlap). This radius can be used to set pscale for copy to points node aswell. ee_circlepack_ctp.hipnc Edited July 16, 2020 by Aizatulin 1 Quote Link to comment Share on other sites More sharing options...
