Crystal Wall Hanging System help
Guys,
I haven't used Houdini in such a long time. Finally i have a project that i believe houdini is best to use for it.
My boss is going to design a wall with different crystals hanging from it, in a pattern. I am attaching the pdf,dwg and dxf of one of the designs.
I remember you can open a dxf file in houdini if you convert the dwg in lines in autocad.
What i want to create is an asset or something that reads this dxf and places the crystals accordingly.
Lets say i have 3 crystals A,B and C (different sizes) in 3d. I want to read my dxf and then copy/instance each model based on the dxf drawing.
The reason i want to do this is because my boss will create a lot of options until he makes his mind and i dont want to do this manually in max.
The download link for the drawings:
http://we.tl/l1hEaLeF8S
Thanks in advance,
Valentino
PS:
crystal_A.pdf
make a line give it enough points and make it vertical
copy crystals onto that (these will be your strings)
then create a curve (set it to nurbs)
resample this curve (this will be the direction of the wall)
use a copy sop to copy the strings onto the curve.
Thanks for the advice guys! Unfortunately i cant go freaq ways since each string is different.
I found a way that works for now. Am turning the drawing in autocad into points, importing this in DWX in houdini and then i instance my crystals on the points.
Anybody knows how to export obj from instance geometry?
