Valentino Posted June 19, 2014 Share Posted June 19, 2014 Guys, I haven't used Houdini in such a long time. Finally i have a project that i believe houdini is best to use for it. My boss is going to design a wall with different crystals hanging from it, in a pattern. I am attaching the pdf,dwg and dxf of one of the designs. I remember you can open a dxf file in houdini if you convert the dwg in lines in autocad. What i want to create is an asset or something that reads this dxf and places the crystals accordingly. Lets say i have 3 crystals A,B and C (different sizes) in 3d. I want to read my dxf and then copy/instance each model based on the dxf drawing. The reason i want to do this is because my boss will create a lot of options until he makes his mind and i dont want to do this manually in max. The download link for the drawings: http://we.tl/l1hEaLeF8S Thanks in advance, Valentino PS: crystal_A.pdfFetching info... Quote Link to comment Share on other sites More sharing options...
edward Posted June 20, 2014 Share Posted June 20, 2014 Copy SOP -- check out the helpcard examples for it. Quote Link to comment Share on other sites More sharing options...
freaq Posted June 20, 2014 Share Posted June 20, 2014 make a line give it enough points and make it verticalcopy crystals onto that (these will be your strings) then create a curve (set it to nurbs)resample this curve (this will be the direction of the wall) use a copy sop to copy the strings onto the curve. Quote Link to comment Share on other sites More sharing options...
Valentino Posted June 24, 2014 Author Share Posted June 24, 2014 Thanks for the advice guys! Unfortunately i cant go freaq ways since each string is different. I found a way that works for now. Am turning the drawing in autocad into points, importing this in DWX in houdini and then i instance my crystals on the points. Anybody knows how to export obj from instance geometry? Quote Link to comment Share on other sites More sharing options...
old school Posted June 25, 2014 Share Posted June 25, 2014 Don't use instances. Use the Copy SOP using the same logic you are using for instancing. That way you have geometry to export. Quote Link to comment Share on other sites More sharing options...
