Solitude Posted September 12, 2014 Share Posted September 12, 2014 Nice work Pav! Quote Link to comment Share on other sites More sharing options...
Artem Smirnov Posted September 12, 2014 Share Posted September 12, 2014 (edited) Awesome job, guys!!! here is my attempt... http://vimeo.com/105993048 Edited September 12, 2014 by Artem Smirnov 2 Quote Link to comment Share on other sites More sharing options...
Solitude Posted September 12, 2014 Share Posted September 12, 2014 Also very nice. Quote Link to comment Share on other sites More sharing options...
zysnow Posted September 13, 2014 Share Posted September 13, 2014 Seems like your link doesn't work for me.. If we talk about name attribute, here is just one requirement: it should be different for all objects. That's pretty easy to do. I'm breaking, recreating (for rebar) and create new constraints (for fractured pieces). question for the rebar part, are you selectively recreating according to some conditions or recreating all of them. if doing selectively, how do you pick the right pair of pieces? Quote Link to comment Share on other sites More sharing options...
vi_rus Posted September 15, 2014 Author Share Posted September 15, 2014 question for the rebar part, are you selectively recreating according to some conditions or recreating all of them. if doing selectively, how do you pick the right pair of pieces? I tried to recreate partly at first, but it didn't work for me. So I switched to recreating for all rebar constraints. Nice work, guys! That's really cool to see such tests Quote Link to comment Share on other sites More sharing options...
Aliencorpse Posted September 16, 2014 Share Posted September 16, 2014 Wow. Excellent work everyone. Thanks for sharing! Quote Link to comment Share on other sites More sharing options...
zysnow Posted September 27, 2014 Share Posted September 27, 2014 (edited) I tried to recreate partly at first, but it didn't work for me. So I switched to recreating for all rebar constraints. Nice work, guys! That's really cool to see such tests I kind of made it work, however,i have to set both bullet substeps and constraint iterations up to 40 to get proper bending result. is it true for your setup? Edited September 27, 2014 by zysnow Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted September 27, 2014 Share Posted September 27, 2014 (edited) Here's a quick setup. Very simple and clean falling plank. You can switch between cone twist and the hard constraint. Hard constraint stiffens up with more subsamples. It also doesn't maintain deformation, it's just slighting bendy. I'm breaking based on the torque attribute, as it seems the most consistent and useful of the available attributes. Awesome Dude! Very clean and easy to understand, thanks for sharing man! Edited September 27, 2014 by Mzigaib Quote Link to comment Share on other sites More sharing options...
michaelb-01 Posted September 29, 2014 Share Posted September 29, 2014 Well, I wasn`t able to prepare a proper scene, so I`m just giving you the messy one! Keep in mind that I simulated it on older H release, so results may not be the same, as there are many changes in bullet solver by now. Hey Pavel, this looks great. Any chance you could do a quick walkthrough of your setup? I'm going through your scene now and doing my best to follow it! Particularly the sopnet inside your dopnetwork. Great work though Cheers, Mike Quote Link to comment Share on other sites More sharing options...
harima Posted September 29, 2014 Share Posted September 29, 2014 Hey guys. I am also trying to recreate your setup with the bendable fracture stuff but I cant get it to work properly. I must be missing something but here is what I am doing at the moment. I set the Pin network and its working fine. I then break it base on torque. if(f@torque>value) setprimgroup(0,"broken",@primnum,1); Now I bring the network with a sop solver connected aside the bulletsolver and I isolate the broken group. Then with an attribwrangle the geo and the broken group connected and by using the findattribvalcount() function I find the objects I need to fracture more. All good. I then switch to the newly fractured geometry .For that I use a switch node with the haspoint expression on it. Basically whenever the broken group from the constraint has points that means we should fracture. So thats when the switch is happening. In order to prevent from fracturing until the end of days I do a check with another switch that looks for the total area of each piece that goes for fracture. So I got that part working. Now I have to recreate the new glue network and pin as well right? cause the pin constraints name no longer match the new geometry right? So here is the part I think I mess up. With a new sop solver this time attached in the constraint network I bring the newly created geometry and trying to create the new network based on that. I am also trying to switch to this new network with a switch as before. So this doesnt work. I feel that the order of operations messes stuff. I mean if we use the network's properties (torque) to shutter the geometry then if on the same timestep we try to update it then who is feeding who? arghhhh.... I tried to dive to Pavel's file and thanks for sharing I got to learn some stuff but his epic extensive use of attribwrangles messed my head after a point Any help and any simple file showing the base logic and how to update constraints is much appreciated 1 Quote Link to comment Share on other sites More sharing options...
sanostol Posted October 12, 2014 Share Posted October 12, 2014 (edited) Great topic and results! What kind of attributes do You use to calculate the stress level. I guess You update (rebar) constraints with high stress levels more than, constraints that have low ones thanks Martin Edited October 12, 2014 by sanostol Quote Link to comment Share on other sites More sharing options...
vfxhound Posted November 19, 2014 Share Posted November 19, 2014 What a great topic! Update! Bendable constrains included. Hi Pavel, this looks amazing! Do you mind sharing an example file with bendable constraints? Quote Link to comment Share on other sites More sharing options...
rayman Posted November 20, 2014 Share Posted November 20, 2014 Sure - I'll prepare some examples. Basically it is Importing Constraints->Transform them using Pieces Positions->Compare Offsets/Forces->Bend(Update)->Transform back to rest space Quote Link to comment Share on other sites More sharing options...
Popular Post rayman Posted November 20, 2014 Popular Post Share Posted November 20, 2014 HIP DOP_BendConstraint_v01_SIMPLE.hipnc 11 Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted November 20, 2014 Share Posted November 20, 2014 Super awesome! Thanks for sharing the hard work Quote Link to comment Share on other sites More sharing options...
vfxhound Posted November 22, 2014 Share Posted November 22, 2014 HIP Thanks a lot Pavel! You're awesome! Quote Link to comment Share on other sites More sharing options...
天城守卫 Posted November 24, 2014 Share Posted November 24, 2014 HIP Hi man! i can't understand the “primintrinsic(1,"packedfulltransform",parIx);”,what is the intrinsic? and what is “packedfulltransform”? Quote Link to comment Share on other sites More sharing options...
rayman Posted November 24, 2014 Share Posted November 24, 2014 This is matrix prim attribute, that stores the transformation matrix of each piece. 1 Quote Link to comment Share on other sites More sharing options...
loudsubs Posted November 26, 2014 Share Posted November 26, 2014 Very cool technique, thank you for sharing Quote Link to comment Share on other sites More sharing options...
asmith1776 Posted December 2, 2014 Share Posted December 2, 2014 I'm trying to recreate Pavel's setup; Can someone tell me why I'm exploding? fracture_tests_4.hipnc Quote Link to comment Share on other sites More sharing options...
