erwinpeters Posted December 8, 2014 Share Posted December 8, 2014 Hi guys, Fresh meat here with what is probably a simply question. I'll get to the point:I want to make these lines, the intersection i mean (disregard the "detail" image. I got it out of my reference material):I have some lines intersecting and i want to add curves to create the round fillets in between. They don't always intersect at 90 degrees. I tried just slicing up a circle and placing it at the intersection but i was unable to make it work reliably enough.There must be some easy way to do this. Some node i have forgotten about or never knew in the first place. Maybe copy the lines and convert them to NURBSs? Any suggestions? Quote Link to comment Share on other sites More sharing options...
freaq Posted December 9, 2014 Share Posted December 9, 2014 afraid this is not an easy task but look here:http://forums.odforce.net/topic/20059-placing-a-circle-in-the-corner-of-a-voronoi-fracture-piece/ Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted December 9, 2014 Share Posted December 9, 2014 i experimented with crossings as well. below are some messy prototypes (there are most likely shorter ways to achieve similar results though).. crossing.hipnc ROAD.hipnc Quote Link to comment Share on other sites More sharing options...
Werner Posted December 10, 2014 Share Posted December 10, 2014 (edited) qlib round corners? https://github.com/qLab/qLib/wiki/Assets Edit Edited December 10, 2014 by Werner Quote Link to comment Share on other sites More sharing options...
dedeks3000 Posted December 10, 2014 Share Posted December 10, 2014 Look here , I think it's what you want to do : http://www.freek3d.com/downloads/Procedural_Railroad_Creation_Hoekstra_Freek.pdf 1 Quote Link to comment Share on other sites More sharing options...
freaq Posted December 10, 2014 Share Posted December 10, 2014 fun to see that come around again Quote Link to comment Share on other sites More sharing options...
erwinpeters Posted December 14, 2014 Author Share Posted December 14, 2014 (edited) Guys, i started reading the manual top to botton and found a fillet-SOP. I don't see anyone using it, though. It is new? I'll play around with it later but it seems to work for nurbs surfaces only. Thanks for the help so far. Edited December 14, 2014 by erwinpeters Quote Link to comment Share on other sites More sharing options...
