[SOLVED]Create Mantra Node Syntax?
Atom
Hi All,
I am trying to create a mantra node and I am guessing at the syntax. I tried this code but is does not work.
mantra_surface = hou.node("/shop").createNode('mantrasurface','my_surface', run_init_scripts=False)
What is the syntax for creating a mantra surface node?
Edited by Atom
'mantrasurface'
is not a valid type - go into shop and then hot TAB to see the list of valid types...for eg put a "Mantra Shader Builder" down, then MMB on the node and you'll see Operator Type: vopmaterial
then this will work:
mantra_surface = hou.node("/shop").createNode('vopmaterial','my_surface')
Mantra Surface is actually not a node type, but a gallery entry. Essentially a preset for the vopmaterial node type.
You first need to create a vopmaterial node and then apply the preset.
mantra_surface = hou.node("/shop").createNode('vopmaterial','my_surface', run_init_scripts=False)
hou.galleries.galleryEntries("mantrasurface")[0].applyToNode(mantra_surface)
it doesn't work this way because the material is in the gallery.
this will Help:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17884&view=previous&sid=ba551930a34b14134fc4810dded192c2
gal_entry = hou.galleries.galleryEntries('mantrasurface')[0]
gal_entry.createChildNode(hou.node("/shop"))
To clarify, the established "rule" is to post on one forum only, and if in a couple of days you get no answer then you can post to the other. Also, if you get good advice or solutions on both forums, it might be a good idea to provide a link from one to the other, so future help seekers can easier find all the good stuff..
