wateryfield Posted February 2, 2015 Share Posted February 2, 2015 Hi, Guys. I get a problem when copy the line along a curve. As you can see from my screenshot, after i copy the line,some vertex number was different with other vertex, so if i skin them, the polygon show interleaving. I try to fix the curve normal before copy, but it still happen sometimes. Is any better way to revision it completely. Thanks. N.hip Quote Link to comment Share on other sites More sharing options...
eetu Posted February 2, 2015 Share Posted February 2, 2015 Having the tangent as your normal seems to screw things up a bit, disabling that from your Polyframe SOP (and using the positive y N defined earlier) seems to fix at least this case. Quote Link to comment Share on other sites More sharing options...
wateryfield Posted February 2, 2015 Author Share Posted February 2, 2015 (edited) Having the tangent as your normal seems to screw things up a bit, disabling that from your Polyframe SOP (and using the positive y N defined earlier) seems to fix at least this case. Thanks for your advice, eetu. But actually i can't just set the positive y N or up, i need the normal along the curve by polyframe SOP(i want copy circle along curve.Use positive y N ,copySOP can't get the right direction). Maybe i can use sweep SOP to replace the copy SOP, but the copy was much more powerful. Edited February 2, 2015 by wateryfield Quote Link to comment Share on other sites More sharing options...
eetu Posted February 2, 2015 Share Posted February 2, 2015 You've probably tried setting N to either the Normal or Binormal as well? Quote Link to comment Share on other sites More sharing options...
wateryfield Posted February 2, 2015 Author Share Posted February 2, 2015 You've probably tried setting N to either the Normal or Binormal as well? I'm sorry, i was confused what you mean about Binormal. Quote Link to comment Share on other sites More sharing options...
