gui Posted March 5, 2015 Share Posted March 5, 2015 Thanks Edward! Quote Link to comment Share on other sites More sharing options...
Atom Posted March 9, 2015 Author Share Posted March 9, 2015 (edited) I am still trying to get Zoki's file to do anything. Zoki says I have to "set the project". Can someone explain what is meant by that statement? I have downloaded the bluewaitStreet.hip file and located the Reload button but I still get nodes in an error state because they are referencing rigs that are external to the posted file. "failed to open ...agents/blue/blue_rig.rig" How do we work with crowd systems? Is there a way to make a self contained file, like Blender can, inside of Houdini that contains all the essential assets? Am I expected to know how to make some default rig to use the above example? A clear working example for noobs would be great to see posted. Should I be concerned about the warnings in the message box? Are these warnings the reason why the posted HIP file does not work for me? Edited March 9, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
michael Posted March 9, 2015 Share Posted March 9, 2015 to set the project: https://www.sidefx.com/index.php?option=com_content&task=view&id=2952&Itemid=403 Quote Link to comment Share on other sites More sharing options...
AdamJ Posted March 9, 2015 Share Posted March 9, 2015 (edited) Agent data is saved by default to $HIP/agents. If you're using someone else's file, most likely you'll be missing it as it's not part of the hip file. Easiest way to rebuild it, is to save hip file in your preferred location and click Render on the ROP network 'agent_bake' in this case(this will write out the needed files). You'll have to click 'Reload' on any crowdsource SOPs so they pick up the saved files. For general setup ideas take a look at the 'examples' on the Crowd shelf. Also, if you click 'Simulate' without giving it any crowdsource objects if will create a default setup for you with some agents walking around (using existing assets that come with Houdini). Help also has a lot of useful info (http://127.0.0.1:48626/crowds/) *Houdini Quickstart tutorials (nice 2-3min short videos to get you up to speed quickly) http://www.sidefx.com/index.php?option=com_content&task=blogcategory&id=253&Itemid=408 I am still trying to get Zoki's file to do anything. Zoki says I have to "set the project". Can someone explain what is meant by that statement? I have downloaded the bluewaitStreet.hip file and located the Reload button but I still get nodes in an error state because they are referencing rigs that are external to the posted file. "failed to open ...agents/blue/blue_rig.rig" How do we work with crowd systems? Is there a way to make a self contained file, like Blender can, inside of Houdini that contains all the essential assets? Am I expected to know how to make some default rig to use the above example? A clear working example for noobs would be great to see posted. Should I be concerned about the warnings in the message box? Are these warnings the reason why the posted HIP file does not work for me? Edited March 9, 2015 by AdamJ Quote Link to comment Share on other sites More sharing options...
gui Posted March 10, 2015 Share Posted March 10, 2015 Has someone tryied to use custom attributes, like custom "state" attribute, to vary agent´s start clip? It´s seams broken, I can´t get to work, even with the default agent. In the help, the attribute is "currentstate" (the crowd source uses "state" attr), but it doesn´t seam to work too... Quote Link to comment Share on other sites More sharing options...
AdamJ Posted March 10, 2015 Share Posted March 10, 2015 (edited) You should be able to override the 'state' attribute (string) either through the randomize option or just plugging in a wrangle after the crowdsource SOP (before the OUT null) and doing if (@ptnum%2==0){ s@state = "run"; } else { s@state = "walk"; } I'll update docs as they're out of date (attribute names changed a few times Has someone tryied to use custom attributes, like custom "state" attribute, to vary agent´s start clip? It´s seams broken, I can´t get to work, even with the default agent. In the help, the attribute is "currentstate" (the crowd source uses "state" attr), but it doesn´t seam to work too... Edited March 10, 2015 by AdamJ 1 Quote Link to comment Share on other sites More sharing options...
gui Posted March 10, 2015 Share Posted March 10, 2015 Thanks! Forgot to test setting the attribute after the crowd sorce.... but I did using the new and cool string vops! Very handy! Quote Link to comment Share on other sites More sharing options...
gui Posted March 10, 2015 Share Posted March 10, 2015 Thanks again Adam, but are you sure it´s working?? I thought it was working, but it isn´t. I tried the randomize function in the crowd source too... Quote Link to comment Share on other sites More sharing options...
gui Posted March 10, 2015 Share Posted March 10, 2015 Well.. it´s working, sorry for the confusion. I just needed to add the states in dop and perhaps a reload in the crowd source! If I have, let´s say, lot´s of clips, is there a way to use them in dops instead of adding lots of state nodes? Perhaps with vops and attributes? Quote Link to comment Share on other sites More sharing options...
AdamJ Posted March 10, 2015 Share Posted March 10, 2015 yeah need to hit reload on the crowdsource so it picks up any clips you've baked out since the initial hip load/last reload. Crowdstate nodes associate animation with states (through detail attribs) and limit scope of forces to only affect particles in that state. Transition nodes also look for them to populate the dropdown menus. In theory you could manage all the attributes in vops/wrangles; as long as they're set to valid agent clip data it should work. Check out the crowdstate/clipdata_detail node Data Bindings tab for the attributes that are being set. Well.. it´s working, sorry for the confusion. I just needed to add the states in dop and perhaps a reload in the crowd source! If I have, let´s say, lot´s of clips, is there a way to use them in dops instead of adding lots of state nodes? Perhaps with vops and attributes? Quote Link to comment Share on other sites More sharing options...
gui Posted March 17, 2015 Share Posted March 17, 2015 Adam, I´m testing rendering crowds with the style sheets. One question now: How can I access a parameter (like a ramp), inside the script? (I have a ramp and want to use a "chramp" function inside the script, but I get an error). I think the crowd solution in houdini is very strong, and could replace our need of massive, one main problema I think is the layers "way" of changing geometry. We can´t iterate over lot´s of options right now, because, as far as I understood, we have to have on layer for each geometry composition. If we could layer layers, we would have far more options... I hope you guys improve this in the near future! Quote Link to comment Share on other sites More sharing options...
AdamJ Posted March 18, 2015 Share Posted March 18, 2015 (edited) I think you'd have to use spline() and fetch ramp parm data yourself as right now there's no way to grab it directly.. (though I just tried this and it doesn't seem to work so not sure if it's supported yet) edit: following should work now; \"cubic\" needed to be escaped since we're passing the whole thing as a json string in quotes "code" : "cvex mFn( int seed = 0; export vector out_color = {0,0,0} ) { float values[] = {`ch("ramp1value")`,`ch("ramp2value")`,`ch("ramp3value")`,`ch("ramp4value")`}; float s = spline(\"cubic\", float(seed/11.0), values ); out_color = set(0,s,0); }", "bindings": { "seed" : "intrinsic:indexorder" } From what Ed mentioned earlier the layer workflow is in it's early stages right now so submit those RFEs Edited March 18, 2015 by AdamJ Quote Link to comment Share on other sites More sharing options...
jason_slab Posted June 23, 2015 Share Posted June 23, 2015 Hi Has anyone figured out a way to randomise agent geometry? I've been trying to see if there is a way to use agent layers to swap out geometry, but not having much luck.For example, I would like to have a agent with say 5 different (geometry) hats that I could randomly distribute across my agents. It seems like it should be a simple copy stamp operation.. hopefully I'm just missing something simple! thx j Quote Link to comment Share on other sites More sharing options...
gui Posted June 23, 2015 Share Posted June 23, 2015 The layers is not yet fully implemented. In my tests, the conclusion I made was that you should bake you character with all the geometry and then, create layers files with each possible geometry, like: layer 0 = no hat; layer 1 = hat 1, and so on. You can edit the layer file that the rop operator saves. Quote Link to comment Share on other sites More sharing options...
jason_slab Posted June 24, 2015 Share Posted June 24, 2015 Thanks GuilhermeI was trying exactly that yesterday, writing out full geo and modifying the agent layer files, well I was writing out multiple layer files, but that didn't behave properly. Probably just due to naming confusion...I have a layer file for "shape": "default.geo" and one for"shape" : "default.hat"I'm trying to vary them using a random layername string attribute. Quote Link to comment Share on other sites More sharing options...
gui Posted June 24, 2015 Share Posted June 24, 2015 Jason, can you share a file for me to take a look? Quote Link to comment Share on other sites More sharing options...
jason_slab Posted June 24, 2015 Share Posted June 24, 2015 Hi Sorry I'm unable to send the file I'm currently working on, I'll try set up a simple scene at home if I get a chance.Thanks for the offer. J Quote Link to comment Share on other sites More sharing options...
Andy Nicholas Posted December 8, 2015 Share Posted December 8, 2015 Hi guys, Just wondering if you got anywhere with the layer manipulation? I'm trying to do something similar where I have 4 different deforming meshes. I've baked the agent with all the geometry inside, and then created extra layer files to support each piece of geometry. E.g. for the layer where the agent is wearing a jersey, I have ./myagent_layer.jersey.lay "deforming":[ { "transform":"geo_Jersey", "shape":"jersey.geo_Jersey", "bounds_scale":1 } ] I've also modified the shapelip Bgeo to make sure the name attribute on the primitive matches (i.e. jersey.geo_Jersey). When I go in to the Agent SOP and change the current layer to jersey, I don't see any geometry at all. Is that normal? I can see geometry for the default and collision layers, but not for the custom ones. Any ideas what's going on? Many thanks, Andy Quote Link to comment Share on other sites More sharing options...
cwhite Posted December 8, 2015 Share Posted December 8, 2015 The JSON snippet looks reasonable, so it would be hard to tell what's going wrong without an example. Note that in H15 there is an Agent Layer SOP that should make additional layers easy to set up. Quote Link to comment Share on other sites More sharing options...
Andy Nicholas Posted December 8, 2015 Share Posted December 8, 2015 HI Cameron, Yep, I agree! It's hard to debug with what I've shown, I was just hoping someone had encountered this already. My impression was that the Agent Layer SOP is intended to be used after the agent has been cached to disk? I.e. to modify the incoming agent for render that's already been cached, rather than being used to generate layers which are then cached out. That's been my assumption up to now as I'm not sure where you'd put it if it's supposed to be used before caching. Will look into it. The other issue with the Agent Layer SOP is that while it appears to be set up to support rigid meshes, but doesn't appear to have anything to allow you to add layers of deformable geometry. I'm still finding my way through all of this, so maybe I've just missed something? Anyway, I'll look at putting together a simple scene together to upload as an example. I've had a few thoughts since my original post that I'm gonna test out first, but either way, I'll post back here tomorrow. Thanks for your help. Andy Quote Link to comment Share on other sites More sharing options...
