@fexternal in Cloth not working ?
Hi Guys ,
I am trying to make @fexternal work on a simple cloth sim.
i just want that my force push only in the area paint in white.
So far nothing look to work and i haven't be able to find a proper exemple on how to use it !
So i must be doing something wrong ... but i need to be sure ... :)
If you have any idea to fix this that would be great !
Thanks for your time
Cheers
E
fexternal_cloth.hip
strange, neither v@force nor v@fexternal work for me either with FE solver
not even POP forces as they used to
(H14.0.292)
haven't tried newest build, but if that's the case, submit a bug
Edited by anim
I agree with you men. It is a bug. In H13 these attributes work well.
But let me introduce you: The Crutch  :ph34r: !
A bit of lyrics:
v1 = v0 + at
F = ma -> a = F/m
v1 = v0 + F/m*t
v1 - velocity at the next timestep
v0 - current velocity
a - acceleration
m - mass
F - force
t - timestep
So if mass equal to one we have
v1 = v0 + F*t
And a refrain;
fexternal_cloth1.hipnc
A wild bug fix appears!
Wednesday, May 13, 2015
Houdini 14.0.333: Fixed support for the external force attribute in the finite element solver. Fixed bug that sometimes prevented DOP forces from properly adding up in the finite element solver.
well i submit the bug on tuesday ... that is fast !
i am wondering if i should submit the issue i have with SBD spring constrain.
http://forums.odforce.net/topic/22409-sbd-spring-constrain-broken-in-h14/?hl=spring
i am not 100% sure that SBD spring should work with cloth, but houdini create all the connection and display them correctly,
it is just that the constrain is not working. the cloth attach constrain work nicely as a replacement.
but do you think it's also a Bug ? and that it should be submited ?
yes there is a bug with spring constraint relationship node the spring constraint relationship node worked well with FEM h13. the "sbd spring constraint" uses this node internally.  the cloth attach constraint doesn´t have a rest lenght attribute so its not a true replacement.
Edited by mattvfx
  • 4 weeks later...
