Flip stick on surface per object
Is there a way other than "Stick on Collision"? So that the fluid sticks on an objects surface but not all objects?
I made local attraction forces with vector fields bad the results or poor in comparison with  "Stick on Collision" option.
Imagine a cylinder on the floor and the flip sticking on the cylinder but not the floor. Is there a way to a achieve this?
I tried Viscosity but it always look too thick even when I turn it down to almost zero.
I hope I am ignoring some magical " Make it Sticky" node... :)
you can use Control Field in Gas Stick On Collision node or directly on FLIP Solver to influence the amount of stickiness
here is a nice example of using painted attribute to generate such control field and use in DOPs:
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=137275#137275
to make that scene to work you may need to bypass (or delete) /obj/emitter/add1 node
  • Like 2
  • 3 years later...
ahhhh  i need this!!!  but where is the topic?  it isnt anymore?? :(:(
  • 1 year later...
