dpap Posted May 13, 2015 Share Posted May 13, 2015 Is there a way other than "Stick on Collision"? So that the fluid sticks on an objects surface but not all objects? I made local attraction forces with vector fields bad the results or poor in comparison with "Stick on Collision" option. Imagine a cylinder on the floor and the flip sticking on the cylinder but not the floor. Is there a way to a achieve this? I tried Viscosity but it always look too thick even when I turn it down to almost zero. I hope I am ignoring some magical " Make it Sticky" node... Quote Link to comment Share on other sites More sharing options...
anim Posted May 13, 2015 Share Posted May 13, 2015 you can use Control Field in Gas Stick On Collision node or directly on FLIP Solver to influence the amount of stickiness here is a nice example of using painted attribute to generate such control field and use in DOPs: https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=137275#137275 to make that scene to work you may need to bypass (or delete) /obj/emitter/add1 node 2 Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted December 30, 2018 Share Posted December 30, 2018 On 5/13/2015 at 4:22 AM, anim said: you can use Control Field in Gas Stick On Collision node or directly on FLIP Solver to influence the amount of stickiness here is a nice example of using painted attribute to generate such control field and use in DOPs: https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=137275#137275 to make that scene to work you may need to bypass (or delete) /obj/emitter/add1 node Expand ahhhh i need this!!! but where is the topic? it isnt anymore?? Quote Link to comment Share on other sites More sharing options...
pxptpw Posted December 30, 2018 Share Posted December 30, 2018 there was a post on custom stick from old school Jeff on the sidefx forum, modified that for h17 file attached , it uses gas match field , so you could set up stick for each object dont know if this was the question, but here you go custom_stick.hiplc 2 Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted December 31, 2018 Share Posted December 31, 2018 (edited) On 12/30/2018 at 4:45 PM, pxptpw said: there was a post on custom stick from... Expand thanks, what i did at the end is a flip with a sop solver chasing a pcloud Edited December 31, 2018 by dyei nightmare Quote Link to comment Share on other sites More sharing options...
bilicsko Posted January 15, 2020 Share Posted January 15, 2020 Quote what i did at the end is a flip with a sop solver chasing a pcloud Expand could you make a screenshot of that sop solver? is it working with a moving geo? thanks Quote Link to comment Share on other sites More sharing options...
