Pass solid color from map into instanced objects
aguzowski
Im looking for clever method to pass color from one object onto instanced objects. But, I want to pass only solid color...
My friend gave an idea to use foreach. Works perfect for simple boxes but it takes eons of time when I change my instaced "spheres" into real complex model.
Anyone got idea how to pass or convert that color data?
Regards
Adam
solid_color_from_map.hipnc.hipFetching info...
post-13590-0-65588900-1432564235_thumb.p
post-13590-0-13159100-1432564796_thumb.j
Thanks for quick replay. I think your setup works fine so far.  Thanks for it.
All I wanted is to pass the color information onto my instanced object but I dont want any color variation on my object just constant color.
When You look closer on my attached image from post 1 you'll see that some of the spheres got "gradient" solor. I want to get rid of that. I want them to inherit just single/constant color.
Sorry for my awkward explanation ;)
Thanks
Adam
Hey Adam, looks like the file from George is doing what you need.  Each points transfers a color to each sphere, so there's no variation of color on the vertices/faces on those spheres.
