Vex - matching target position in DOPs
Juraj
Hi
I am trying to dive into VEX. And I made up a little assigment for myself - do an assemble effect in DOPs.
However when matching target position and orientation there is a slight offset occuring in orientation. (img_1)
But if I do this position and orientation adjusting (same method) based on simpler rule (frame number) it works as expected. (img_2)
Could somebody look into this file and check what may cause this problem?
Thanks,
Juraj
project.hipnc
post-11577-0-76679400-1444081889_thumb.j
post-11577-0-56963200-1444081892_thumb.j
matching transforms is not enough, you need to match pivots as well
so just insert this code somewhere after you populate align variable
vector pivot = primintrinsic(0, "pivot", @primnum);
vector pivottgt = primintrinsic(1, "pivot", @primnum);
pivot = lerp(pivot, pivottgt, align);
setprimintrinsic(0, "pivot", @primnum, pivot);
Awesome!
Now it works, thank you.
However I am not sure I understand this pivot thing. How is intrinsic "packedfulltransform" computed? Is it computed by attribute @P, "transform" intrinsic and "pivot" intrinsic? What role does "pivot" intrinsic play in bullet sim? And why is it changing during simulation? Isn't pivot of transformation encoded into "transform" intrinsic matrix?
