Skybar Posted January 11, 2016 Share Posted January 11, 2016 I got a couple of spheres I want to render with refraction. They are pretty low res, and I wanted to subdivide them at rendertime. However the poles get all screwed up (see pictures) and this is clearly visible in the refraction. I've noticed this lots of times before but it never really was an issue. Is there an easy fix for this? Probably a noob question but I have no clue really. I could go back and use the "polygon"-sphere (made up of only tris) instead, but then I'd have to resim and all that. Cheers! Quote Link to comment Share on other sites More sharing options...
Atom Posted January 11, 2016 Share Posted January 11, 2016 (edited) When I want a sphere without pole issues I will use a sub-divided box. Edited January 11, 2016 by Atom 1 Quote Link to comment Share on other sites More sharing options...
f1480187 Posted January 11, 2016 Share Posted January 11, 2016 (edited) You can idealize bad-shaped sphere with something like this: vector min, max; getbbox(min, max); vector center = avg(min, max); float radius = avg(max - min) / 2; // Spherify. @P += center; @P *= radius / length(@P); // Spherical normals. @N = normalize(@P - center); Replacing geometry completely with NURBS sphere using Match Size SOP is the best solution, probably. Why have to resim? spherify.hipncFetching info... Edited January 11, 2016 by f1480187 1 Quote Link to comment Share on other sites More sharing options...
Skybar Posted January 11, 2016 Author Share Posted January 11, 2016 That's great! Thanks a lot Quote Link to comment Share on other sites More sharing options...
acey195 Posted January 12, 2016 Share Posted January 12, 2016 On 1/11/2016 at 3:15 PM, Atom said: When I want a sphere without pole issues I will use a sub-divided box. or use a geodesic "Polygon" in Houdini sphere topology if you want to subdivide afterwards, I would still do this in combination with something like the vex wrangle mentioned before. especially if you are using the subdivided cube approach Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 23, 2017 Share Posted June 23, 2017 (edited) i gotta admit...noobs like me got it easy these days...just take a look how easy it is to Spherify something in H16...and set normals in the same node...but what if the object is not at Origin ? well dive in the file and see... more shenanigans in video.. Spherify_H16.hipnc Edited June 23, 2017 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
