FBX animation import as copy reference
Saya
hello odforce,
not sure if this is the right section but heck. :)
As I as search the internet for tutorials I got some inspiration and wanted to try something.
I saw a tutorial inwhere the pointsofvolume sop was used. I used a testobject for this sop and it worked.
But know I thought, this should also work with animation. I had imported a fbx and wanted to connect it
to the pointsofvolume sop. But I can't reach the fbx since the fbx is on obj level and the pointsofvolume
sop in a geo. Im looking for a method to import the fbx in this geo sop. Can someone help me out?
I have added a picture for clarity
post-7207-0-58454500-1456053339_thumb.jp
Edited by Marcomeeuwse
  On 2/22/2016 at 12:37 PM, Marcomeeuwse said:
... But i needed to select a geometry node in the fbx.
Not the subnet of the fbx....
if you want to bring in geometry from multiple objects in single Object Merge, you can use patterns
/obj/subnet1/*
will bring all geometries from objects directly in subnet1
/obj/subnet1/*/*
will bring everything from objects directly in subnet1 and one more level (from other subnets in subnet1)
/obj/subnet1/box*
will bring geometry from objects starting with box which are directly inside of subnet1 etc...
  • 5 years later...
Well, sorry but I have the same problem.
I used file -> import -> Filmbox FBX.
I created a new geometry, placed inside an object_merge and used wildcards. When I render my object_merge, I can see my object rendered corretly.
Then I created a curve and used "folow path". A constraints is correctly created. But when I change the frame, the object is not mouving.
I then created a new geometrie, placed a file and loaded a ".sc" object. With the same procedure, the object moves correctly.
Is there a paramer which locks the object_merge or prevents it to move and follow the path?
Thank you !
