Atom Posted February 26, 2016 Share Posted February 26, 2016 Hello All, I am trying to embed the transform of an object traveling along a path into the vertices locations of the exported geometry sequence. So when the sequence is brought back in the object travels along the path in the sequence without the path being present. Putting a ROP Output Driver inside an object that is following a path does not seem to work. The object gets exported, however, it remains at world origin even if I enable Transform Into World Space. I tried Object Merging the object that is traveling along a path into another geo and exporting from there, the same result. I found an old setup that shows a point moving along a curve. The object gets copied to the point. This does make the ROP Output Driver embed the transformation but when I copy an object onto the point it does not align to the path. It only transforms along the path without rotation. I am attaching my example file setup if anyone has any ideas on how to add rotation to the object traveling along the path? ap_align_to_path_issue.hipnc Quote Link to comment Share on other sites More sharing options...
Juraj Posted February 26, 2016 Share Posted February 26, 2016 Hi, objet merging works for me. Just don't forget to set Transform parameter to Into This Object. You can set this parameter to permanent defaults. If you still want to use Copy SOP way you can do it but you have to prepare vectors for orienting. You can use either N attribute which is simpler option or you can recreate coordinate system and use it as orient attribute. Juraj jt_path_bake.hipnc Quote Link to comment Share on other sites More sharing options...
dedeks3000 Posted February 26, 2016 Share Posted February 26, 2016 Resample your curve help to define better tangent vector. Not sure if the orientation is enough robust. ap_align_to_path_corrected.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted February 26, 2016 Author Share Posted February 26, 2016 Thanks for the solutions, they both work! Quote Link to comment Share on other sites More sharing options...
