mosssi Posted March 3, 2016 Share Posted March 3, 2016 Hi guys I'm trying to simulate a dripping effect like the attached photo but my object is a sphere which doesn't have a concave surface and it can't hold water. So do you know a way that I can emit flip from the wet surface of the sphere in the way that look likes it is drying for few seconds? I tried emitting Flip from object but it emits from a SDF and its nothing like this dripping. Thank you Quote Link to comment Share on other sites More sharing options...
Ceonsamea Posted March 16, 2016 Share Posted March 16, 2016 I'm also very interested in this. I have been trying to set up a scene which allows fluid to drip down the sides of an object and then form into droplets on the underside. However, as an absolute beginner in Houdini I'm not sure about how to approach this.It seems that by default liquid does not properly stick to surfaces realistically. Presumably this is because most of Houdini's default settings are intended for larger scale simulations?I have been experimenting with "stick on collision", surface tension and viscosity but can't seem to get a convincing result.I spent a lot of time searching around the internet but haven't had much success in finding relevant content. If any of you more experienced users could shed some light or point us in the right direction it would be highly appreciated! Quote Link to comment Share on other sites More sharing options...
Navneet Arora Posted March 28, 2016 Share Posted March 28, 2016 i too would be really interested if some could explain this methodology. i have been trying using dot product to break the liquid when it is at certain angle but it seems that it isn't working. Any insights on this would be of great help.. Quote Link to comment Share on other sites More sharing options...
miccetro Posted June 12, 2016 Share Posted June 12, 2016 Would be great if someone could shed some light on these techniques. Quote Link to comment Share on other sites More sharing options...
vijayakumar Posted June 16, 2016 Share Posted June 16, 2016 U can try scattering points onto the geometry and directly call into source volume(source flip). then slow down the nearby particles on surface of the sphere.. check if this method works and let me know. spheredripping.rar 4 Quote Link to comment Share on other sites More sharing options...
Farmfield Posted June 16, 2016 Share Posted June 16, 2016 On 6/16/2016 at 8:53 PM, vijayakumar said: U can try scattering points onto the geometry and directly call into source volume(source flip). then slow down the nearby particles on surface of the sphere.. check if this method works and let me know. spheredripping.rarFetching info... Expand Oh, that's cool. Really cool. Exchanged the sphere for a torus, added some rotation, just to see how it would handle a more complex object and movement - and it did, brilliantly. So yeah, an awesome setup. A much appreciated share for sure. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted June 19, 2016 Share Posted June 19, 2016 On 6/16/2016 at 8:53 PM, vijayakumar said: U can try scattering points onto the geometry and directly call into source volume(source flip). then slow down the nearby particles on surface of the sphere.. check if this method works and let me know. spheredripping.rarFetching info... Expand Is this setup using all the nodes inside? I see mypoints used for the SOP Solver, etc but there is no mypoints. Are these nodes not used? It would be nice if the scene was cleaned up from unused nodes. Quote Link to comment Share on other sites More sharing options...
vijayakumar Posted June 20, 2016 Share Posted June 20, 2016 On 6/19/2016 at 11:05 PM, magneto said: Is this setup using all the nodes inside? I see mypoints used for the SOP Solver, etc but there is no mypoints. Are these nodes not used? It would be nice if the scene was cleaned up from unused nodes. Expand mypoints is the name for geometry points where dist attribute is calculated. In gas particle to field the geometry we want to process is specified.. so in this case its mypoints. Please take a look at the gas particles to field node. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted June 20, 2016 Share Posted June 20, 2016 On 6/20/2016 at 3:59 AM, vijayakumar said: mypoints is the name for geometry points where dist attribute is calculated. In gas particle to field the geometry we want to process is specified.. so in this case its mypoints. Please take a look at the gas particles to field node. Expand Thanks, I checked it but I don't see mypoints group created in SOPs or in DOPs and I inspected the Geometry in the DOP and still don't see any mypoints group. If you dive inside sopsolver in the middle of the simulation, you will see that dop_geometry node still has 0 points. I disabled the sopsolver and the result looks the same. Can anyone verify this please? 1 Quote Link to comment Share on other sites More sharing options...
vijayakumar Posted June 20, 2016 Share Posted June 20, 2016 On 6/20/2016 at 5:20 AM, magneto said: Thanks, I checked it but I don't see mypoints group created in SOPs or in DOPs and I inspected the Geometry in the DOP and still don't see any mypoints group. If you dive inside sopsolver in the middle of the simulation, you will see that dop_geometry node still has 0 points. I disabled the sopsolver and the result looks the same. Can anyone verify this please? Expand Hi magneto, you were correct. it was not reading the points since it is connected to vel volume. sorry..i should have converted into fields and then read the dist..wanted to make it fluid slow near the sphere.. but the vel as a whole got slowed down it seems. il check into it and update the file. thanks. 1 Quote Link to comment Share on other sites More sharing options...
vijayakumar Posted June 20, 2016 Share Posted June 20, 2016 (edited) Ok. here is the updated version on fields.. previously it wasn't working. in gas field vop, distance and speed ramp(promoted outside) controls how particles stick to the surface. spheredripping01.hipFetching info... Edited June 20, 2016 by vijayakumar 8 Quote Link to comment Share on other sites More sharing options...
