6ril Posted March 3, 2016 Share Posted March 3, 2016 (edited) Hi, first off, I'm totally new to any kind of programming language. Yet I'm trying to convert a point SOP expression into VEX in a pointwrangle. $TX * ($TY / $YMAX) is the line I'm trying to write in VEX. My problem is the $YMAX I reckon $TX becomes @P.x but I'm not able to find the equivalent for $YMAX $YMAX is the maximum value of any point in the Y axis, right? (I'm not even sure) So I searched the help for a max function, but it seems to be only to compare between 2 thing. Can anyone help and correct me? thanks. Edited March 3, 2016 by 6ril 1 Quote Link to comment Share on other sites More sharing options...
jmpr Posted March 3, 2016 Share Posted March 3, 2016 Try this inside a wrangle node vector min; vector max; getbbox(min,max); //Instead of $TX * ($TY / $YMAX// @P.x *= (@P.y / max.y); Good luck Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted March 3, 2016 Share Posted March 3, 2016 (edited) try this: whenever you see "&" sign, sort of means it will modify the data in it. here is the function from the documentation: void getbbox(int input, vector min&, vector max&) -----code---- //empty vectors vector min; vector max; getbbox(0, min, max); //find bbox f@ymax = max.y; //exportedit: should be float sorry Edited March 3, 2016 by willow wafflebeard 1 Quote Link to comment Share on other sites More sharing options...
6ril Posted March 3, 2016 Author Share Posted March 3, 2016 (edited) Thanks guys ! a few steps closer to mastering VEX ! only a million left... Edited March 3, 2016 by 6ril Quote Link to comment Share on other sites More sharing options...
6ril Posted March 3, 2016 Author Share Posted March 3, 2016 Another question : this "expression" $TX * (($TY / $YMAX)+1) is from this very nice tutorial of Konstantin Magnus - > https://vimeo.com/112114913 (Procedural Modeling of a Shampoo Tube) It's actually a very important part of the procedural modeling method. It's reshaping a tube into the body of the shampoo tube. In one point node. x: $TX * ((($TY / $YMAX)+1)*0.45) y: $TY z: $TZ * (1.02 - ($TY / $YMAX)) but unfortunately, he doesn't develop the though process leading to this expression. So my question is, how does one come to approach simple pinching on a tube, with such an expression ? I'm aware this question might sound rather naive, you might tell me "learn your maths!" or something. But I'm just wondering if there's some "references" somewhere, or, Konstantin, would you mind telling me how you figured this one? Did you create it out of the blue ? I imagine that, by analysing what you need to do to the points, on the different axis, to get the shape you want, there's an "obvious" relation between the amount you need to move them and the height (y) of each point, but, I'm sensing that my background would have lead me to a soft selection approach rather then this nice mathematical approach. Should I worry about that ? Does it mean the Houdini isn't the tool I should try to learn ? Quote Link to comment Share on other sites More sharing options...
iamyog Posted March 3, 2016 Share Posted March 3, 2016 $TX * ((($TY / $YMAX)+1)*0.45) should translates into VEX as float ymax = ch("ymax"); float multiplier = ch("multiplier"); @P[0] = (@P[0] * ((@P[1] / ymax) + 1) * multiplier); You need to add 2 parameters to your attribWrangle interface. It can be done manually via the little gear on top, or since H14, by clicking the "plug icon" next to the VEX expression field, H will create any parameter that you have referenced in your code via the ch() expression. In the ymax parameter, just type this expression : bbox(opinputpath(".", ), D_YMAX) and it will read the maximum Y value on the first input (index ) of the current node (".") The good thing about the second parameter, called multiplier is that you can now play in real time with the value and see how it affect the shape in your viewport. If you know the shape of your object is supposed to follow a certain pattern (pinch on a certain axis, bulge elsewhere, ...) you can code the pattern and just use parameters to find the correct values. Experiment with ramp parameters, called within VEX via chramp("name", attribute). 1 Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted March 5, 2016 Share Posted March 5, 2016 (edited) sorry for the broad answer, but: your mindset regarding 3d graphics changes the longer you use houdini. so its defintely worth keeping at it. and talking about 'wanting to use the soft selection node' i think its only natural to first try the things you know from other packages. but over time you will appreciate building your own tools that are based on simple mathematics, because they are more elegant and direct and because you know exactly what they do. as far as i remember i didnt write this expression in one go. rather i first put in what i knew was necessary like the relative height of each point and then i started adding stuff to see what happens. nowadays i would probably do it more with VOPs and wrangles, i guess. two more recommendations: http://www.gametutor.com/live/tutorials/houdini/ and once you got that and you dont mind it being in russian: Edited March 5, 2016 by konstantin magnus Quote Link to comment Share on other sites More sharing options...
