PlatinumFishy Posted April 29, 2016 Share Posted April 29, 2016 (edited) I am trying to make a simple drill using a cone and a spiral sweep polygon. I try to cut into the cone using the spiral sweep but I can't seem to get the cookie to work properly. Any suggestions or alternative ways to achieve this? Spiral.hipnc Edited April 29, 2016 by PlatinumFishy Quote Link to comment Share on other sites More sharing options...
Atom Posted April 29, 2016 Share Posted April 29, 2016 Just making a few changes on the Cookie node seems to bring it into shape. Here is a related link on modeling threads. ap_Spiral.hipnc Quote Link to comment Share on other sites More sharing options...
fathom Posted April 30, 2016 Share Posted April 30, 2016 my general opinion is to not use cookie. ever. 2 Quote Link to comment Share on other sites More sharing options...
6ril Posted May 1, 2016 Share Posted May 1, 2016 cookie works pretty well with watertight geo. Quote Link to comment Share on other sites More sharing options...
acey195 Posted May 1, 2016 Share Posted May 1, 2016 3 hours ago, 6ril said: cookie works pretty well with watertight geo. if you can be 100% sure that the geometry does not have geometry at the same position at the cookie object (incidental faces) and it will also quickly fail with very sharp angles (high frequency noise) I think. For one-off tasks cookie is fine, if you can always verify the result. For more procedural tasks, I go with Fathom... avoid them like the plague, locking yourself into using cookies is a bit of a "newb trap" :P, because you have to be sooo careful with your procedure that you will likely limit the possible outputs more than you would using other methods. Sure it is often a bit more work, but VDBs or clips are much more stable. Quote Link to comment Share on other sites More sharing options...
6ril Posted May 1, 2016 Share Posted May 1, 2016 Right, but clip is a very limited action, and VDBs are great unless you work on a large complex model (a full building for example). I've only used cookie once, for a building that I need to expose via complex animated clipping, and it was (with my level and with the help of this forum) the only way to go. I tried VDBs / combine/ convert, but it is way way too slow when you need to keep fine details. Of course, a more reliable cookie sop would be very very welcome ! Quote Link to comment Share on other sites More sharing options...
acey195 Posted May 1, 2016 Share Posted May 1, 2016 ok yeah for maintaining sharp corners VDBs are kind of heavy if the details are small. There are some tricks you can do with the clip node though , you can save the point positions, then deform the object so that it is unwrapped along the cutting line, clip it, and restore the original point positions. Credit to Kim for giving the idea: Just rewrote the basics in VEX, and note that this method does have some quirks as well, but those are mostly inaccuracy problems, actually break it is a lot harder than with a cookie MorphClip.hipnc 1 Quote Link to comment Share on other sites More sharing options...
wateryfield Posted May 2, 2016 Share Posted May 2, 2016 4 hours ago, acey195 said: ok yeah for maintaining sharp corners VDBs are kind of heavy if the details are small. There are some tricks you can do with the clip node though , you can save the point positions, then deform the object so that it is unwrapped along the cutting line, clip it, and restore the original point positions. Credit to Kim for giving the idea: Just rewrote the basics in VEX, and note that this method does have some quirks as well, but those are mostly inaccuracy problems, actually break it is a lot harder than with a cookie MorphClip.hipnc Pretty awesome way, Twan Working far better than cookies or VDB! Quote Link to comment Share on other sites More sharing options...
