cone_constraint_problem
some power users will probably spot out a main possibility from the video, but it would help to have the hip file to investigate quickly.
have you tried to increase the "angular threshold" (in DOP/wall RBD packed object/bullet data tab)? To help calm down the slow stumbling pieces, but won't calm down the high spinning ones :/
I don't know the exact cause of this but I it may be from:
- Your constraints length and rest parameter in cone twist constraint node. (the constraint primitives should be zero in length)
- The breaking constraint method which you use. (you delete primitives by a large force threshold or ...)
