vfxing123 Posted June 1, 2016 Share Posted June 1, 2016 how to get this effect . anyone have good idea? Quote Link to comment Share on other sites More sharing options...
Atom Posted June 1, 2016 Share Posted June 1, 2016 That looks like a mix of the Saber Plugin and Optical Flares both available on VideoCopilot. http://www.videocopilot.net/tutorials/saber_plug-in/ Quote Link to comment Share on other sites More sharing options...
vfxing123 Posted June 2, 2016 Author Share Posted June 2, 2016 Quote no i want know how get effect in houdini .or houdini idea? thank Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted June 2, 2016 Share Posted June 2, 2016 It's not practical to implement an effect like that in Houdini because it's mostly compositing tricks, hence the After Effects plugin links above. It could be done in Houdini but it wouldn't make sense to do it. If you decide to try it in Houdini let us know the problems you're running into and we can help there. Simply asking how to do something complex like that out of the blue isn't a good way to get people to help you (it makes you look lazy and ungrateful). Showing what you've tried so far or where you're getting stuck at least shows you're willing to put in the effort. 1 Quote Link to comment Share on other sites More sharing options...
cgcris Posted June 2, 2016 Share Posted June 2, 2016 I would probably do a pyro sim to get the whispy/smokey feel and then advect particles with it.. Quote Link to comment Share on other sites More sharing options...
altbighead Posted June 2, 2016 Share Posted June 2, 2016 1.run a fluid sim to get the general motion 2.run particle sim using fluid velocity 3.run a few wedges so that you get lots of points. 4.shade those points using density so you you get hot core Quote Link to comment Share on other sites More sharing options...
vfxing123 Posted June 5, 2016 Author Share Posted June 5, 2016 thank you i will try.... Quote Link to comment Share on other sites More sharing options...
