jiayujinn Posted June 23, 2016 Share Posted June 23, 2016 (edited) Hello everyone, I would like to ask about how to import an open vector illustrator file in houdini to make an open curve? My ai file is saved as ai 8. Please see the files I attach below. Thank you so much! Fingerprint.ai (.ai) (.c4d) (.hip) Edited June 23, 2016 by jiayujinn Quote Link to comment Share on other sites More sharing options...
Atom Posted June 23, 2016 Share Posted June 23, 2016 Just save it out as a .abc from Cinema4d and bring it into Houdini. The Illustrator workflow is limited in Houdini. fingerprint.abc 3 Quote Link to comment Share on other sites More sharing options...
jiayujinn Posted June 23, 2016 Author Share Posted June 23, 2016 16 minutes ago, Atom said: Just save it out as a .abc from Cinema4d and bring it into Houdini. The Illustrator workflow is limited in Houdini. fingerprint.abc I am such an idiot, have been trying all day and didn't think of .abc Thank you so much! Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted October 28, 2019 Share Posted October 28, 2019 Zombie thread alert. I figured I'd share this solution for folks that come across this thread in the future years later like I did. The Ends SOP node can be used to delete the loop so the curves are open instead of closed. Set the Close U parameter to Open and it should work. 2 6 Quote Link to comment Share on other sites More sharing options...
Computing0251 Posted October 21, 2025 Share Posted October 21, 2025 @lukeiamyourfather In 2025 Houdini 21.0 this still works. Thank you!!! Quote Link to comment Share on other sites More sharing options...
Keerah Posted October 30, 2025 Share Posted October 30, 2025 There's also this nifty little python tool for vector import Quote Link to comment Share on other sites More sharing options...
