squardis Posted July 30, 2016 Share Posted July 30, 2016 Hi, Im stuck with something simple. but cant get my head around it. there are serveral switches in VOP's Now for example how to turn a switchs the other way around? instead of giving it two inputs and a comparison, I need to compare if a toggle is 0 or 1 and give it based on that a noise on a Cd or a noise on a P attribute. Thnx. Quote Link to comment Share on other sites More sharing options...
Sean-R Posted August 1, 2016 Share Posted August 1, 2016 Sounds like a two way switch is what you need. Plug the toggle into the condition, then the two noises into the two imputs. Input 1 is for 1 and Input 2 is for 0. Quote Link to comment Share on other sites More sharing options...
squardis Posted August 1, 2016 Author Share Posted August 1, 2016 No, thats not it, it needs to output it to color or to a displacement, so i mean two outputs. not inputs Quote Link to comment Share on other sites More sharing options...
Skybar Posted August 1, 2016 Share Posted August 1, 2016 You can use two Two-Way Switches, or an If block. Quote Link to comment Share on other sites More sharing options...
cgnema Posted August 2, 2016 Share Posted August 2, 2016 Hey Squardis, I'm not 100% sure I understood your question, but let me know if this file helps. vops_switchDispOrColor.hipnc Quote Link to comment Share on other sites More sharing options...
squardis Posted August 2, 2016 Author Share Posted August 2, 2016 8 hours ago, cgnema said: Hey Squardis, I'm not 100% sure I understood your question, but let me know if this file helps. vops_switchDispOrColor.hipnc Thanx cgnema! thats exactly what i meant. thnx Quote Link to comment Share on other sites More sharing options...
